how level is level?
Old Jun 7, 2004 | 09:35 PM
teckert's Avatar
how level is level?
After I hook-up my 5th to my truck my camper has about 7 inches between the bed rails and the camper. When I measure the frame of the camper to the ground I am about 2.5 inches higher in the front. Not quite level but close, what are the tolerences for this to ensure the load is evenly distributed? I'm pulling a 29 foot 02 Cougar.
Old Jun 8, 2004 | 04:33 AM
Casey Balvert's Avatar
I have always tried to be within an inch front to back. A lot will depend on how heavy that back axle is loaded when you are hooked up. The main problem with running a trailer that is not level is overloading one of the two axles over their design limits. I would expect that each situation is different depending on trailer weight and axle ratings.
Good luck. Casey
Old Jun 8, 2004 | 10:59 AM
roadranger's Avatar
A bumper pull trailer has to be pretty close to level to avoid induced sway.
Your 5er may be more forgiving in this respect, but as stated above, be careful of overloading that rear axle. You won't like it when the inevitable blowout wipes out the rear half of your RV!
Old Jun 8, 2004 | 08:14 PM
FiverBob's Avatar
Actually, most fivers will balance the weight between the axles due to the arm between the axles. However, I would sure lower your hitch one inch and keep the 6" bed clearance. It should help porpoising. The ideal is to run level on most units.
Old Jun 9, 2004 | 09:40 AM
welder27's Avatar
That's interesting...I've seen a few people here who don't seem to care that their 5th wheel isn't balanced! Maybe they're just moving them across town for a friend, but still...
Old Jun 9, 2004 | 12:34 PM
Maccandy's Avatar
FiverBob is right. "I would sure lower your hitch one inch and keep the 6" bed clearance. It should help porpoising. The ideal is to run level on most units."
6" is enough room between the truck and the fiver.
jmccart
Jun 14, 2008 10:29 AM
jmccart
Feb 18, 2008 10:27 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
pwabbott
31
Dec 4, 2002 09:09 AM
