Generator adjustment Screw?
Old Feb 13, 2010 | 10:27 PM
Roperteacher's Avatar
My new generator works great! It "Pulsates" ever so slightly but noticeable. I read online where there is an adjustment screw you can tweek to smooth it out? I called manufacturer and they said normal and after a couple tanks of gas it will loosen up and run smoothly. Isin't there an adjustment screw I can tweek a little? I had to do the same thing to my water pump in the trailer and it worked wonders! THankS!
Old Feb 14, 2010 | 11:56 AM
bentwings's Avatar
I'd give it a little time. Put a small space heater on it for a load for a while so it can break in. My little 3500 did the same thing at first but settled down as I loaded it. Even after 250 hours it still has that slight surge when it is really cold out...-10 F but as soon as I load it, it smooths out.
jmd4993
Jun 22, 2013 07:36 AM
97catintenn
Apr 16, 2006 07:40 AM
loudcummmin
Oct 3, 2005 02:44 PM
4x4dually
Feb 14, 2005 10:20 AM
