Front mount hitch receivers?
Old Jul 16, 2006 | 04:41 PM
packard8's Avatar
Does anyone have info on one that will take more than a 500lb vertical load? I want to relocate the parking space for my 24’ trailer (empty weight is around #4500, guessing tongue weight is 700-800?), and a front mount would make sticking it into a tight spot much easier. The only ones I find in a google search are rated at 300 to 500lbs.
Thanks
Old Jul 16, 2006 | 05:28 PM
satburn's Avatar
Did a quick search and found similar results for either a Reese or Curtis hitch. I did find another forum where someone had recently had one made that was heavier than normal. Read the last post at the bottom of the thread.
http://www.rv.net/forum/index.cfm/fu...g/17753624.cfm
Old Jul 16, 2006 | 05:30 PM
Marine's Avatar
Veteran: Marine Corp
You won't have any problem if your hitch is rated for 500#. It's not like you are running down the highway with it. I have one, and have moved trailers with at least 500# tongue weights.
Old Jul 16, 2006 | 06:53 PM
Homestead's Avatar
For moving a trailer around your yard, I wouldn't worry about your tongue weight being over 500 lbs.
All your doing is parking a trailer, not cruising the interstate.
Jeff
wcjp's Avatar
Not sure of the rating. Have you tried Torklift? I had everything Torklift on my 96'. Sure is easy to manueaver stuff off the front.
Old Jul 16, 2006 | 09:07 PM
packard8's Avatar
Thanks for the replies. I suspect that most hitches are underrated for liability reasons, and a #500 rating would prolly work fine for my purposes (doubt that I’d exceed 3 MPH while positioning a trailer). I looked at the Torklift website but didn’t see any front mounts. I’ll check with a local dealer next week.
Thanks again,
John
Old Jul 16, 2006 | 09:44 PM
Marine's Avatar
Mine is a drawtite, and I believe it is rated for 500#. I looked at the website, and it says 300# now. I'll look on the hitch and let you know.
D45
Apr 6, 2009 02:27 AM
patdaly
Jan 7, 2008 11:54 AM
91.5CTDBanks
Aug 11, 2006 05:59 PM
sdaly
May 16, 2006 04:08 PM
Don H
Mar 13, 2005 11:50 PM
