Are Featherlite/ Aluminum trailers really worth it ?
But with all that said, it never works long term. The welds will eventually crack along their edges. So essentially, yeah, I guess the crack got fixed, but what REALLY happened is you just moved the crack over the width of the repair. Which is now under the patch and SOOOOO easy to re-repair again. If it's tubing, an inner patch like a smaller piece of tubing could be used to double the effective thickness of the material, but again, you're just moving where the next crack will appear. With any frame section in a trailer, it's going to move and flex with road conditions, and aluminum just doesn't like to flex much.
And just for the record, Featherlite, who I was a dealer for, were the absolute WORST for frames and goosenecks cracking on their horse trailers. They didn't want anything fixed either. Their philosophy was replace or destroy.
So go ahead stick boy, pick it apart!
Then can you explain why most coil haulers and super load trailers are aluminum? Not being a smarty just asking
Sent from my DROID BIONIC using Tapatalk
Because they're probably all of 500 pounds lighter than an all steel trailer. And if you notice the next time you see one up close, the suspension is probably sub-framed with steel. I've only seen one or two trailers that went with aluminum suspension hangers and they were about 3" thick.
I really don't know how much lighter they get using aluminum over steel, but in the grand scheme of things, it ain't that much. Maybe 1500 pounds? Yeah, it gives them more payload, but the trade off is the repairs. And if you're talking a gross weight of 80,000 pounds, 1500 is next to nothing.
Well then just go ahead and enlighten us, oh Fuseologist of the Heavens.
Should the OP buy an aluminum trailer, and develop a crack in said aluminum trailer, what is the only way to keep it from running?
I shall humbly await for you to bestow your knowledge upon us mere mortals.
Well, this thread has been successfully derailed.
Do you guys remove the mats and clean out all the wetness after each use? If you don't, lift the mat and have a look. I think you'll be surprised at all the deep pitting, if not outright holes. My shop back in Massachusetts used to replace about one floor a month. Probably still do. Horse urine and aluminum make a very corrosive mix that doesn't take long to destroy a floor.
Now Mr Smarty pants. You want the truth?
You cant handle the truth.
We're all waiting with bated breath! The future of DTR, no wait, the whole INTERNET, hinges on what you're gonna say! But you better hurry up... I gotta GO!
