Dodge vs. Ford - HELP!
Help me out here guys and gals. A friend of mine is planning to retire in a few years, sell the house, buy a new truck and RV and RV full-time. He says that the RV that he's looking at weighs in around 17.7K and that by Dodge's own specs, a 3500 won't handle it but a F350 will. I looked and Ford does appear to have a higher rating. Is this just PR spin and hype or does the Ford handle the larger load better? What has to be done to a Dodge to make it handle the larger RVs?
Thanks in advance
Thanks in advance
The trailer is too heavy for a 1 ton . Tell him to avoid the Ford 6.0 Powerstroke . If he really wants a trailer that size , he'll have to go to a larger truck but the trailer must be huge and something I wouldn/t want to haul much . He'll be burning a lot of fuel and having a hard time manuevering it .
I agree
Pulling 20K for 80 miles just about literally brought my truck to its knees, for something like that if he wants a ford really bad get a 450 or 550 but with the rep that 6.0 is developing, I DONT THINK it be a wise investement, a medium duty like buckshot said would do just fine..
Tx
Tx
Thanks guys.
I don't get the impression that he really WANTS a Ford because he was seriously looking at Dodge until the specs issue came up. In looking at Ford's web site, it really looks like the F350 DRW single cab w/ the 6.0L diesel
, an automatic transmission, the 4.3:1 rear end, and the TowBoss package is rated for 19.2K. What I don't know is whether comparing this to Dodge's rating of 16.3K is comparing apples to apples. Ford's GCWR is 3K higher than Dodge's for some reason.
I know nothing about RV towing so I'm looking to you for information. I know that some of you RV full-time or for extended periods of time. What do your RVs weigh and what have you had to do to make your Dodge handle it?
Thanks again.
, an automatic transmission, the 4.3:1 rear end, and the TowBoss package is rated for 19.2K. What I don't know is whether comparing this to Dodge's rating of 16.3K is comparing apples to apples. Ford's GCWR is 3K higher than Dodge's for some reason.I know nothing about RV towing so I'm looking to you for information. I know that some of you RV full-time or for extended periods of time. What do your RVs weigh and what have you had to do to make your Dodge handle it?
Thanks again.
Originally posted by njoverkill
What is a F350's GCWR? That is a big trailer...
http://www.fordvehicles.com/trucks/s...res/specs/#tow
Dodge claims 23K
http://www-5.dodge.com/vehsuite/dispatch.do
My Dad has been towing his boat/trailer combo behind his '96 3500 Ram with no problems since the truck had 0 miles on it. No problems, the trailer/boat weighs in at 17,500!!
Add in the truck weight and
There are guys like Haulin that tow a bunch more-I think he uses a 2500!!
.There are guys like Haulin that tow a bunch more-I think he uses a 2500!!
Originally posted by 12valve@heart
Ford claims 26K
Dodge claims 23K
Ford claims 26K
Dodge claims 23K
TowBoss Pkg
(Mfr. Code: 53B)
Rear Axle, 4.30 Ratio Limited Slip
Notes and Relationships
Requires 5 Speed Automatic w/Overdrive & TorqShift 44B Transmission, and Turbo Diesel, 6.0 Liter Engine: V8.
And my fifthwheel is only about 10,500lbs. With the weight he's talkin about pullin it must be over 40feet long!
