differential temperature
Old Nov 29, 2007 | 02:52 PM
Nonstop's Avatar
what i meant was there close in temp, the pans a little cooler than then hot line. When i'm working the truck, like towing, i'll see a bigger spread.
could the different weights and types of fluid, trans fluid vs diff fluid, be throwing the sender off? different resistance in the fluid?
Old Nov 29, 2007 | 09:11 PM
CrazyCooter's Avatar
You may need a ground from the frame to the diff housing.
The only grounds it gets otherwise are via u-joints, parking brake cables, and shocks.
Run a quick jumper and see if that makes a difference.
Old Nov 29, 2007 | 09:24 PM
Nonstop's Avatar
I've run a ground, too. From frame to cover bolt, nothing changed.
Old Nov 22, 2024 | 08:26 AM
Jamesharrison@1's Avatar
Originally Posted by bulabula
I think he was referring to the fact that you have two probes in your truck - on in the trans pan and one in the diff pan (unless you switch them rapidly) - and that the one in the diff pan may not be working correctly.
Why don't you invest in an IR thermometer, and take the truck for a fast run down the highway. When it gets up to 250F, pull over onto the side of the road and shoot the diff temp on the pan. At least you'll know if it is indeed 250.
Personally, if it isn't making any noises/whining, I'd drive the heck out of it and wouldn't worry about it.
JUST listening in " I don't know ' I Drove PETERBILT'S my whole life And I can tell you more than you want to know " but if that 'diff ' is runnin (250.f) that's going to 'burn' up " I'm just wondering if it's got the right"grease/additive" in it" James.
Jim Lane
Jul 13, 2012 08:58 PM
Hummin Cummins
21
Mar 28, 2003 03:22 PM
Grampaw
Feb 5, 2003 09:28 AM
waam
21
Jan 2, 2003 07:28 PM
