CHAMPION 12v winch?
Old Aug 1, 2005 | 11:14 PM
moopa's Avatar
Question CHAMPION 12v winch?
Has anyone heard of this type of winch? Does anyone have one they can comment about? It's for sale at Costco In BC Canada for $400.00 for a 8000 lb with power in and out. remote, fairlead, mounting bracket and about 90' of cable. I need it for pulling 3800-4000 lb. cars in and out of my enclosed car hauler. I'll only use it about a dozen times a year, if that. It's way less than 1/2 price of a similarly equipped Warn. Just wondering if it's a case of "you get what you pay for" (junk) or if it will work for my uses?
Thanks, Mark.
Old Aug 3, 2005 | 06:30 AM
Bart Timothy's Avatar
I don't know anything about Champion winches (except that their imported from China), or what your trailer setup is like, but I'd say an 8000 lb winch is overkill. If you're on a budget, a 1500 or 2000 lb winch sould do the job easily, and can be had for under $100.
Old Aug 3, 2005 | 07:58 AM
pittom's Avatar
Don't forget the 8000lb is only rated for the 1st winding (laver of cable) as you add 2 or 3 lavers it changes the ratio so your 8000lb is less.
Old Aug 3, 2005 | 02:14 PM
phox_mulder's Avatar
I'd say for that price, and how often you'll be using it, it should be fine.
I wouldn't rely on any "off name" winch for recovery purposes, but for that, no problem.
phox
Old Aug 3, 2005 | 02:43 PM
CTD NUT's Avatar
FWIW, that winch is slower than molassas in Janurary.....a guy in our 4x4 club bought one and it is painfully slow but does pull strong......you get used to all these lightening fast modern winches.....you get what you pay for, I guess. IMO, you would be much better off with a 2500 - 3500 lb ATV/Utility winch.....the line speed will be much more desirable and the winch will be much lighter and more compact.....Lots of guys around here are using 1500 - 2000 lb winches to pull their cars onto trailers without any problems.
Old Aug 3, 2005 | 06:15 PM
CarolinaThunder's Avatar
I have a superwinch 4500 in our racecar trailer and it pulls great and very fast, I got for $400 if I remember correctly.
Mike D
NCDTR #18
Sep 11, 2008 08:37 PM
12valve@heart
Oct 11, 2007 11:09 PM
RAF
Sep 20, 2007 05:15 PM
PourinDiesel
Sep 9, 2007 12:50 PM
mule3010
Dec 5, 2006 08:38 AM
