Brake controller harness????????
Old Jun 25, 2008 | 06:19 PM
corygale's Avatar
am attempting to istall brake controler but cant locate my harness anywhere, is it sometimes hidden up behind something 2004 2500 ctd with tow package your help is appreciated and if it isnt there how hard to install brake controller with out it
thanks people
Old Jun 25, 2008 | 09:16 PM
stumpjumper's Avatar
it should be a four pin connector either blue or white right next to parking brake pedal...your truck has a tow package so it should be there...
if not then you need 4 wires power,ground, brake signal coming from the brake switch and a wire going to the back of the truck for trailer brakes.
Old Jun 25, 2008 | 10:42 PM
corygale's Avatar
Ive searched cant find it I have the towing package but truck was bought used so I have no Idea what was done to it before I got it??thaks for the info ,
cory
Old Jun 25, 2008 | 11:42 PM
big horn06's Avatar
On my "06 2500, I had to use a mirror up the outboard side of the park brake pedal to see the controller connection. It's a blue plug zap strapped wayyyyyy up in the top corner behind where the brake pedal attaches to the firewall. There were 2 bolts holding a big white electrical box thing which I removed, cut the brake controller connector free and rebolted. Take a look at yours, it should be the same if you have the factory tow package.
Old Jun 26, 2008 | 01:00 AM
Colo_River_Ram's Avatar
With age comes the cage
Here you go it's on top of the white cover..leave it in place and plug in your controller harness.. I bumped this up on another post as well...
https://www.dieseltruckresource.com/...4&d=1192808816
Old Jun 26, 2008 | 03:09 AM
Jim Wilson's Avatar
It's kind of in a bad place with that loom of wires right in front of it. I just pulled them down a bit and got the top of the connector in then pushed the wires down with the conector and slid it in. You can always remove the white box if you have trouble with that.
Old Jul 2, 2008 | 12:08 PM
corygale's Avatar
thanks guys found it appreciate the info right where you said but hidden quite well
cory
TrueBlueInBak
Oct 18, 2007 08:41 PM
j
Jul 25, 2007 12:47 PM
MR HYDROSEED
0
Mar 27, 2005 06:54 PM
linetrash75
Oct 10, 2004 06:05 PM
erics76
Dec 27, 2002 05:19 PM
