Any thoughts on putting a set of truck rims and tires on my trailer
I have a jayco eagle 341 rlqs. It has 16" 8 bolt rims, and 235 80 16 tires. A friend has a set of rims off of an old truck of his, they just happen to match the rims on my truck. They are 16 x 6.5" and the tires are 245, 70 16. Do you think that this will work? I believe that the bolt pattern is the same.
Thanks
kevin
Thanks
kevin
Sounds like a nice upgrade! Are the wheels aluminum? I broke a set of car-type aluminum wheels installed on a homemade bunkhouse trailer backing into a tight spot during deer season. The center section was not used to the side loading that tandem trailer axles get while being pushed into tight turns. They were definitely aluminum car rims, 4-bolt Ford from a Tempo, if I remember right, not truck rims.
HDBeauty
May 31, 2009 06:02 PM
1320
May 29, 2009 10:24 PM
rowley_141
Jul 20, 2008 02:02 AM
sakisaki400
23
Dec 31, 2006 10:17 PM
