5th wheel + GooseNeck Hitch
I'm looking to put in best dual 5th/gooseneck hitch solution (will be towing both: goose soon, 5th later). If you planned to do both (on a short-bed, like mine) what would be the best product/solution? I'm leaning towards the SuperGlide (18K) with the GooseNeck adapter (w/ball).
TIA,
Dane
eta I got this input so far (from other thread):
TIA,
Dane
Last edited by Dane Bramage; Feb 10, 2008 at 03:10 PM. Reason: added recommendation quote
I'd have to agree with 4x4Freak. I've got the B&W gooseneck in my truck now, just haven't bought the Companion 5th wheel setup yet. I like it, the only holes in the bed are the one 4" for the ball and 4 for the safety chain hooks. Easy installation and has worked great for me.
My old truck had the 5th wheel rails in the bed, I hated it, always swapping out the gooseneck plate and the 5th wheel hitch, plus when I wasn't towing, them rails were always in the way.
I'm a big fan of the B&W myself it has more options for towing hookups..Click on the Accs tab to check out the hook-up options. It only takes about 2 hrs to install..
http://www.turnoverball.com/turnover.asp
Ok, Im not disagreeing with these guys on the B&W, its a great hitch. But Dane needs a slider because he's driving a MEGACAB, not a quad cab. This is important because the mega has a shorter bed, therefore we have clearance problems. Dane, I suggest you go with the superglide, I have it, and I know from experience, as I too pull gooseneck horse trailers as well as my fifth wheel travel trailer. You won't be disappointed, its a great hitch. If you have any questions or need anymore info, shoot me a PM.
Thanks for the input. I've been investigating the B&W turnover ball product a bit. Seems the best option for GN. I realize trying to get the best for both 5th + GN will be a compromise. I think, for the 5th, I really want/need a slider with the short-bed. The B&W product does not slide (manual nor auto), correct?
It may actually be quite a while before I get the 5th though... so the best compromise might be to get the B&W turnover and be able to enjoy the use of the bed when not towing (no rails).
eta:
Thanks txfiremedic! ~ we were typing at the same time, apparently.
I can shoot you a PM but may as well get some details out here for anyone else curious. Seems as though it would be a fairly common scenario but I did not get anything on the searches.
Slider desired indeed! Do you run the superglide with that same gooseneck adapter I linked? If you would be so kind perhaps you could share details on how involved the adding/removing of the GN adapter is, any installation experience, etc.,. General question on the superglide - how difficult is it to remove and how much space is taken up in the bed? (I can search on that last q).
Thanks again!
Dane
eta:
Thanks again!
Dane
Last edited by Dane Bramage; Feb 10, 2008 at 03:39 PM. Reason: tring to keep up with txfiremedic!! lol
Dane, the B&W does NOT slide, and to answer your second question, with the superglide, you can still use the bed when not towing. The hitch is attached to truck by 4 pins that once the hitch is taken off the pins, the pins rotate and lift out so you are left with nothing in your bed other than 4 -2 inch holes that the pins drop down and secure into.
there are pics in my profile of my setup...
You guys already had your
LOL! I'm trying to keep up - seems my additional questions are answered even before I finish my post.
Thanks again txfiremedic! If the superglide removes down to that, it's a 100% golden solution for my application(s). Is it heavy/difficult removal process? And how about the switch with the GN adapter? (easy?)
Cheers,
Dane
!LOL! I'm trying to keep up - seems my additional questions are answered even before I finish my post.
Cheers,
Dane
It is heavy, but SUPER easy to take out, the pins that go through the bed have a hole in them, the hitch sits on those and have a pin that goes through the hitch and them. You pull those out, lift the hitch off of them and then those pins just twist and lift out of the bed. I know you won't be dissappointed, its a great hitch, my only regret is that I didn't buy it sooner!
have you guys seen the 5500 with the 10" bed in the 4500/5500 section..
http://news.windingroad.com/concept-...-bft-for-sema/
"BFT" indeed.
10" had me curious (world's shortest short-bed?). 10' - now that makes sense.It is heavy, but SUPER easy to take out, the pins that go through the bed have a hole in them, the hitch sits on those and have a pin that goes through the hitch and them. You pull those out, lift the hitch off of them and then those pins just twist and lift out of the bed. I know you won't be dissappointed, its a great hitch, my only regret is that I didn't buy it sooner!
Which superglide model did you go with? From their website, there seems to be three GN adapter model options:
¹ To be used with 16K & 20.5 Super 5th
² To be used with 25.5 & Low Profile Super 5th
³ To be used with 14K or 18K SuperGlide
How does the GN adapter install? I'm guessing it mounts somewhere to the base-plate and doesn't also slide.² To be used with 25.5 & Low Profile Super 5th
Thanks again!
