285-70-17's on a dually?
Old Oct 9, 2007 | 10:29 PM
bigwheels94's Avatar
Hey. will 285-70-17 tires fit on stock dually rims, without spacers? I'm converting my truck to a dually, & allready have the E rated Toyo 285-70-17's on my truck. With the Arrowcraft conversion spacers, I can't use any spacers between the rims.
Old Oct 10, 2007 | 06:14 AM
1tonmegacab's Avatar
285 70 17 is the size of the stock dually tires i am pretty sure but i know thats what i have on my truck with no spacers
i have the stock steel wheels on the inside i am pretty sure that everybody with after market wheels use the inside steelies
awesome where did u find all the parts
Old Oct 10, 2007 | 06:25 AM
Old Oct 10, 2007 | 11:44 PM
I'm getting the axle spacers from Arrowcraft. The Fenders from dually fenders .com, but I'm having trouble finding wheels anywhere except from dodge for $270.00 each.
Old Oct 11, 2007 | 06:49 AM
i bought my two rear ones off ebay let me look and see if the seller has more
even though i searched high and low with different searches on ebay i found nothing but then this guys info popped up on accident
let me look and see if he has more they were 130.00 each plus shipping
also i will look on the other forums i go to and see if anybody has any
what r u gonna use for wheels i see now they have wheels just like mine in a 19.5 with 8 lug which is awesome
also i imagine u r buying the reamer for the steel wheel holes from arrowcraft also i dont rem how much the reamer is but i have one that u could use
if not to late then shipping for the reamer and from me to you and then back to me could be cheaper than buying one
Old Oct 11, 2007 | 06:55 AM
he has two availible and his user name is coloradowheelcompany
he wants 138.00 each plus 25.00 shipping each so roughy 320.00 for for the pair shipped to your door and i got mine within 3 days of paying with buy it now ( so if u bought today u would have them early next week)
i was in a big rush to get mine ( not enough to pay extra shipping) so i called him to make sure he knew i used buy it now because it was early enough in the day so they could be still shipped that same day
not sure what rule is for posting ebay links here but if they delete it let me know i will email the info to you
http://cgi.ebay.com/ebaymotors/17-Do...mZ280151006621
Old Oct 11, 2007 | 08:07 AM
Rollin' Smoke's Avatar
so you guys are running 285/70/17's on a dually with no spacers? I am about to put some 295's on mine and I really dont want to add a 2" spacer. was thinking of doing something smaller. anyone of you have pics of the gap between the wheels?
Old Oct 11, 2007 | 08:28 AM
Dodgezilla's Avatar
285s are NOT the stock size!! 245s are stock for 3rd gens and I think 235s were on the 2nd gens. Big difference there..........
Old Oct 11, 2007 | 08:48 AM
well i thought ( and should have) i said i think instead i am pretty sure ( should have just got out of truck and looked lol) but as usual i stand corrected
mky truck has 235s on it will get u a couple pics of space between wheels i do have adapters on my truck but the gapis the same as my buddies stock 3500
Old Oct 11, 2007 | 06:02 PM
Dodgezilla's Avatar
I'd like some 285s for mine too but Man! That's a lot of scratch for 7 tires!!! I'm planning on going to 265s when it's time.....
Old Oct 11, 2007 | 08:48 PM
Yeah, it is. But I allready have 5 of them. I just need to know if I can get them on without spacers. Then, when I get the Arrowcraft extensions, I can just get 2 more. I'm allso leaving to go hunting for the next 3 weeks, & the whole shebang will have to wait 'till, I get back.
Old Oct 12, 2007 | 04:20 AM
Dodgezilla's Avatar
From what I have read, They will fit must the gap between them is very small. If you hit a big bump then when the tire squats they may rub which may eventually cause a blowout. The same holds even more true when you try to tow. Since those tires don't have as stiff of a sidewall I would just make sure you keep them aired up to the max if you try it. I'm sure there are guys out there that are doing it with no spacers.....
Old Oct 12, 2007 | 08:51 AM
induchman's Avatar
They're too wide and you will have tire failure. Most dealers won't install those tires, unless they are OEM's. Liability issues. You'd better better off going with 19.5" rims and stiffer sidewalls.
Old Oct 18, 2007 | 12:17 PM
dezeldog's Avatar
FWIW, my 03 came with 235/80-17 on it.
jim
Old Oct 19, 2007 | 12:15 PM
tankn60's Avatar
jim
My 07 also came with 235/80-17's on it.
If I rember right the Dodge dually's from 94-02 came with a 215/85-16's, and from 03 and up they come with 235/80-17's.
