07 underpowered?
Old May 26, 2007 | 02:26 PM
REF>Lancer's Avatar
07 underpowered?
A friend of mine bought a new 07 CTD 6 speed,crewcab,and the thing won't spank mine loaded or unloaded on level 2 on the edge,is there something strange about the way the are rating the newer trucks? its supposed to have 325hp (he said) but my pump aint tapped,and that makes a +65hp difference.
so 245+65=310 hp right? what gives?
Old May 26, 2007 | 02:56 PM
Danderson's Avatar
Smarty & '07
My '07 was a dog stock as was my '99. I installed a Smarty on the '07 and it's a different vehicle now. Plenty of power on the low levels.
Old May 26, 2007 | 03:53 PM
bob4x4's Avatar
remember the new truck ratings are not at the wheels,and the emmisions software doesn't give a ton of torque down low.
Bob
Old May 27, 2007 | 10:42 AM
rich's Avatar
my 07 with the 3 dog will spank the crap out of a lot of trucks with or without the 8k gn on it, has he removed the restrictor in the air tube
Old May 27, 2007 | 01:17 PM
REF>Lancer's Avatar
Not as far as I know,I doubt that he's messed with it at all,where is it? how hard is it to get rid of?
Thanks
Old May 27, 2007 | 03:27 PM
bigwheels94's Avatar
My friend has the same truck. It does OK, but it is still opening the waste gate too early between 2000-2500rpm. It's really noticable now with the AFE-II. Turbo spools,& then dumps several times between those rpm's. He's called DC several times, & they say they've never heard of that problem before. Does yours do that too?
Old May 27, 2007 | 07:11 PM
rich's Avatar
take the air tube off in front of the turbo and their is a white plastic device in it with fins its hard to remove but i got mine out it doesnt restrict a lot but it does some
Old May 27, 2007 | 10:37 PM
bob4x4's Avatar
I think you are way off base,the tube flows an additional 100 cfm with the vanes in place on a flow bench.............
Bob
Old May 28, 2007 | 01:25 PM
HAY BURNER's Avatar
[QUOTE=bob4x4;1526762]I think you are way off base,the tube flows an additional 100 cfm with the vanes in place on a flow bench.............
Bob[/QUOT
I would like to see the test results for that
Old May 28, 2007 | 06:06 PM
REF>Lancer's Avatar
Uh oh,better wait for you guys to battle this one out!
