Reply question
Ok, when I reply to a qusetion or comment on this site, how do I get it so the person that I am replying too gets on the reply. I know, I probably didnt say that right but, for example....Mr. Jack Thorpe has a thread going and I want to copy what he said....and put it in my reply to the thread, how do I get it so his name is in the reply? What I have been doing is going down and copying what he said......then hitting the quote button and pasteing what I copied.....but then it only says in the reply "quote". How do you make it put in whom its from?
There I think I said it right that time...:D |
Re: Reply question
Originally posted by GIT-R-DONE Ok, when I reply to a qusetion or comment on this site, how do I get it so the person that I am replying too gets on the reply. I know, I probably didnt say that right but, for example....Mr. Jack Thorpe has a thread going and I want to copy what he said....and put it in my reply to the thread, how do I get it so his name is in the reply? What I have been doing is going down and copying what he said......then hitting the quote button and pasteing what I copied.....but then it only says in the reply "quote". How do you make it put in whom its from? There I think I said it right that time...:D You can go in and edit out parts of the quote, but be sure to leave these two things alone... QUOTE].../QUOTE] They have to be in place ahead and behind the actual quote to work properly. I hope this helps, Lary |
Instead of using the reply button, or the quick reply box on the bottom of the thread, you hit the "quote" button which is at the bottom right of every post. This will make it so their text is populated into your reply. You can then move it around and make it understandable for the next reader. I hope this helps.
Originally posted by Jack Thorpe Instead of using the reply button, or the quick reply box on the bottom of the thread, you hit the "quote" button which is at the bottom right of every post. This will make it so their text is populated into your reply. You can then move it around and make it understandable for the next reader. I hope this helps. or maybe you do and I dont know about it......thanks guys Don |
See, there you go! :)
Works great. [laugh] |
