Stranded in Calgary! T-Case gonzo
Old Feb 23, 2011 | 10:49 AM
Rick 12v CTD's Avatar
So I left Monday to head to Calgary from home to visit a friend. After Winnipeg I could hear my t.case making more and more noise. Then finally just before Medicine Hat it got kinda bad. I managed to limp it all the way to Calgary but it's pretty well finished.
Now begins the ardent task of finding a replacement for a reasonable price (because that's all I can afford) and replacing it myself with a very limited set of tools, outside in the cold in the driveway! And I kinda need it done in a week to week and a half.
Anyone in the Calgary area have or know of a good used auto np205? that won't cost me an arm and a leg of course
Old Feb 23, 2011 | 10:56 AM
Jungle's Avatar
you need one for the CTD. The gaser has a smaller input bearing.
Jim
Old Feb 23, 2011 | 11:03 AM
Jim
yeah I thought they were different. Thanks.
Old Feb 23, 2011 | 11:33 AM
simplysmn's Avatar
Gasser work's just fine I used 1 on my last truck and never had any problem's so Expand your search
Old Feb 23, 2011 | 11:35 AM
1-5-3-6-2-4's Avatar
drop a post in to the Alberta DTR #5 section on the bottom of the page. theres a bunch of us in and around calgary. someone might have one ready to go, I'm not sure.
Old Feb 23, 2011 | 01:16 PM
I assume it's the gasser auto that would have the same input. What years will bolt up?
Old Feb 23, 2011 | 02:53 PM
roxxx's Avatar
I will look I know the wreckers are charging silly bucks
EDIT : Tim in Trochu Heavy metal wreckers maybe 403-442-2600
Edit: not sure it saz Dodge and Chev kijij Ad ID 257507614 if so very good price
And in St Albert
Old Feb 23, 2011 | 03:37 PM
simplysmn's Avatar
pretty much all the late model 205's will fit I have used the early 80's on up n they bolt up no problem
Old Feb 23, 2011 | 04:32 PM
Thanks Simply.
And in St Albert
that one seems to be a divorced case though. Is the yoke over the input shaft or? I'm not entirely sure how that works with the divorced cases.
Plus, that's probably too far! :S
I did find another one on kijiji but I'm just waiting on a response back from the guy. Hopefully he doesn't want too much for it. He didn't list a price.
I'll probably give that Tim fellow a call.
Thanks.
Old Feb 27, 2011 | 10:26 AM
update!
Tranny is toast too. Won't shift out of first and it slips pretty bad when you first try to go. Fluid looks about the same as motor oil that's got 10k miles on it. I don't think there was any fluid mixing or anything though. The fluid level is bang on right where it should be.
Looks like I'm towing it home some way or another and parking it for a good long while.
Old Feb 27, 2011 | 11:09 AM
ClassA4x4's Avatar
Originally Posted by Rick 12v CTD
update!
And who knows, tranny may just be the problem, i.e. the NP205 is OK? It'd be weird having both toast at the same time; besides, the NP205' are supposed to be (almost) bulletproof.
Good Luck!
Old Feb 27, 2011 | 11:24 AM
Good Luck!
that's kinda what I was thinking. Although I do think some of the bearings in the transfer case are on their way out. It has almost 300k miles on it and 2 yeas ago the t.case was kinda run through the ringer when my truck was stolen. When I do the trans I'll probably do a rebuilt on the case too. It's not even $200 for a rebuild kit for the 205 so knocking off 2 birds with one stone seems like a good idea to me.
Old Feb 27, 2011 | 12:35 PM
Mark Nixon's Avatar
If it puked the O/D unit, it'll sound for the world like the T-case took a dump.
Check the t-case lube level, chances are if it's up, it's not a part of the problem.
Mark.
Old Feb 27, 2011 | 03:57 PM
307Kenworth's Avatar
Call Holst Truck Parts in Ucon Idaho, My old one is sitting on their shelf.
Old Feb 28, 2011 | 12:54 AM
Mark.
yeah that's the first thing I checked. The fluid level was all good in the transfer case.
wyododge
Aug 18, 2011 07:48 AM
admin
Oct 29, 2002 09:36 PM
admin
Oct 15, 2002 08:29 PM
