Quiz for you all
Quiz for you all
And Mark Nixon already know's this one because he helped me with it . Thank's Buddy
OK Have a 91.5 reg cab 4x4 auto that the guy fired the engine harness and the under dash wasn't much better well 3 day's Later it's all been changed to 93 wiring and ECMQuiz question is What does the 91.5 Not have that the 93 has ? My problem is No charge and no OD yes speedo work's Got any Idea's . It's Kinda funny but I spent half a day tracking this down .
Val
OK Have a 91.5 reg cab 4x4 auto that the guy fired the engine harness and the under dash wasn't much better well 3 day's Later it's all been changed to 93 wiring and ECMQuiz question is What does the 91.5 Not have that the 93 has ? My problem is No charge and no OD yes speedo work's Got any Idea's . It's Kinda funny but I spent half a day tracking this down .Val
Val
91.5 does not have a crank sensor . . .you need it for the 93 PCM to work.
91.5 also has an overdrive control module next to the glove box that 92 & up do not have.
92 & 93 will not charge without a crank sensor.
DING DING DING Yes Sir you hit the Nail on the Head No CPS but it will soon have 1 that's for sure . Now The Question is I have to make sure the front will take a Crank sensor it has the double notch ballancer so I am good there just have to make sure it has the holes for the bolt's to mount it .it's a 7 of 1991 truck so I should be ok .
The module for 1990-'91 is mounted under the dash, near the E-brake pedal.
O-BTW, I have seen 2-notch dampers as early as late 1990 in Dodge trucks.
This is required for the factory-supported add-on tachs that the Japanese supplied to the Dodge dealers.
Mark.
