will 36's fit?
Old Jan 31, 2006 | 01:01 PM
getblown5.9's Avatar
will 36's fit?
is it possible to get a 36x12.50 to fit on a leveled 2nd gen with only trimming the inner fnder liner and not touching the body work of the truck. also with my custom bumper, there is no lower bumper edges to catch the tire either.
also i rarely wheel this truck...it might see mud once or twice a year, but nothing major, or alot of flex
Old Jan 31, 2006 | 01:13 PM
Cowhand's Avatar
I ran 36's with 4.5" of lift and they still rubbed on the fender behind the tire.
I'm not talking about flexed out, I'm talking curb cuts.
I'd say no.....
Old Jan 31, 2006 | 01:44 PM
will a 315 rub?
Old Jan 31, 2006 | 02:52 PM
dieselrob's Avatar
i have 315s on for over a year and they only rub 4 wheelin once in a great while.
Old Jan 31, 2006 | 02:53 PM
thanks...ill stick with the 315's that my buddy is gonna sell me then
Old Jan 31, 2006 | 03:35 PM
RowJ's Avatar
GB5.9
35's on my leveled 02 (2" frt lift) rub anytime you go full lock on the steering wheel.... either direction!
I just don't go over 1&1/2 turns on the streering wheel and never have a problem! (1&3/4 turns is full lock).
Easy to get use to...except when you forget
RJ
Old Jan 31, 2006 | 04:57 PM
NHDiesel's Avatar
The big reason most larger tires rub is because most are wide. Rams seem to really be affected by width differences. I had a friend who 'wheeled a stock height 1500 Ram with Q-78 tires (aprox. 36" tall) and they hardly ever rubbed. But they were much narrower than most oversize tires, at around 9.5" wide. That keeps them inside the fender, and away from the control arms. He had aftermarket wheels, but I don't know if the backspacing was close to stock or not.
Jim
Old Jan 31, 2006 | 06:37 PM
newriverSpecon's Avatar
With the stock suspension 315/75R16 on our 97 rub on the upper control arm and on the plastic fender liner on the rear. I did trim the bottom of the front bumper about 1/2" or 3/4" tapered to nothing at the top. It would have torn it off if I had not. I think the shape fits better now anyway. As said a turn and a half keeps them off the arms.
Randy
Old Jan 31, 2006 | 08:51 PM
one54ton's Avatar
Lift it you hillbilly...
Old Jan 31, 2006 | 09:02 PM
got...DIESEL?'s Avatar
my 35's clear "on-road" just fine lock to lock with the 2" levelers. Even when hitting pot holes they do fine. Wheel offset has a big role in whether they'll clear or not. 36's just might a tad too big for no problem clearance. I have 16.5X12.50's on a 10" wheel with a standard offset FWIW.
Good luck
Chris
Old Jan 31, 2006 | 10:08 PM
I would but I just bought shocks for both trucks. EBAY'ed some Bilstiens for less then $450. I'm thinking this would be a good time to throw the blocks in though. And I was trying to save this bonus check. I hat e you people!!!
Randy
Wade
Dec 19, 2002 08:21 AM
state line
Dec 9, 2002 10:40 AM
rschaer
Nov 4, 2002 07:09 PM
