Where to wire the low fuel pressure light?
Old Jun 11, 2007 | 12:41 PM
Tommy93w350's Avatar
I have the low fuel pressure kit warning with a campaign pump, but where does it wire up at?? Where is the warning light?
Old Jun 11, 2007 | 12:42 PM
DMcPherson's Avatar
if yo ugot the wiring kit with the lift pump then it needs to be calibrated to recognize it and it sets the check engine light. I would much rather see a gauge or an led wired into it
Old Jun 11, 2007 | 10:06 PM
I have a electric gauge, just want a redundant warning in case my electric is not accurate.
Old Jun 11, 2007 | 11:29 PM
camelracer's Avatar
Try wiring it into the high side (black/white) of the washer fluid level switch. The low fluid dash light will come on when either the fluid is low or your fuel pressure drops. If you keep the fluid level up you will know it's a fuel pressure problem.
Old Jun 12, 2007 | 07:53 AM
That's pretty clever!!!!! Thanks
bc3
Dec 1, 2007 10:19 PM
Rollin Smoke
Oct 24, 2006 10:24 PM
Txwelder
Feb 11, 2006 10:32 AM
matthopp
May 11, 2004 04:38 PM
TPilaske
16
Nov 22, 2002 08:15 PM
