Where to set my Timing???
I would like some advice on where to set my timing, Im just going to play with the truck sledpull/drag race, its not my daily driver so heres my mods.
-DTT auto tranny by Timinva
-Htt 71 series 66/13 stainless
-O ring head, pocket port,60#springs with 12mm studs
-215 pump 0 plate, 4k springs, laser cuts, gutted afc
-.093 injection lines feeding 370's
22-24* with all that fuel youll need some decent timing. it will spray outside the bowl but the concetration of the injection event will still be in the bowl.
ive been everywhere with timing, and when i was on a stock motor with a 66mm single i ran 23*
now with my s400 and marine pistons i run 30* and its my daily driver.
If you run that much timing 18*-20*with the 370s you will burn the tops of your pistons (not good).
You will need to pull one to see if the stamp says 370 on the side of the injector.
Check out New Era diesel, they sell some nice injectors for the money and they have the correct spray pattern. That way you can run alot more timing.
(these are marine 370's right) I would say 16*-16.5* IMO!
. No I dont know for sure but I just know that 16* would keep a little more fuel in the bowl than 18*-20* IMO.
