what will I gain?
what will I gain if I swap my plate that is in my sig. with the #100 that is sitting on my work bench?
thanks Tanner |
[roll] nobody?[roll]
?so no one knows what I would gain? |
well from what i know about 12 valvers is that the 100 plate is the same as a zero plate, just fuels on top more, i think do a search on the zero plate and see what comes up.
here check this thread this should help you tell the difference. https://www.dieseltruckresource.com/...ight=100+plate |
HP wise it's hard to say, depends alot on where you'd position it and how you adjust it.
Diesel Dummy: you're kinda right, the 100 and 0 plate are close but the 100 defuels on the bottom end, where the 0 does not defuel. Willy |
Originally Posted by 12valveford
(Post 1157519)
power, smoke and EGT's the 100 plate is deeper then the 8! |
wont hurt my fuelmileage then?
foot purdy much to the floor to do 82 down the interstate at 18.5 mpg is this gonna change |
pretty close im not a 12valver. LOL.
