what is this turbo????
Old Jun 2, 2003 | 07:32 AM
gunracer1's Avatar
i picked it up friday, it is a little bit smaller than than a ht3b, but the impeller is a 1/4" larger than a ht3b. it came off a big v8 cummins with a lot of made in england cast on it. anyone reconize it. it has cummins #s that says t 50. mike
gunracer1's Avatar
Re:what is this turbo????
one more
and the beer can is for refrence only
Old Jun 2, 2003 | 09:24 AM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
It came off a Cummins VT-555-C engine. The base V-555 engine put out about 250 hp. Max output was up around 350 hp. It was a slow speed engine with an upper rpm limit around 2000rpm. Used mostly in large agri and construction equipment. The turbo model is T50. It was a slow turning unit and max boost was somewhere around 22-28 psi but put out a large volume of air.
Hope that helps.
shortround out
Old Jun 2, 2003 | 09:40 AM
Don M's Avatar
DTR Advertiser
Some of the tractor pullers have tried that turbo or variants of it with limited luck. The T-50 is a cheap turbo and can be had new for less than 5 bills. Long ago I talked to Pius about one....cuz I had found one cheap and he laughed at me. Said they were pretty cheesy for big boost apps without hybriding, etc.<br><br>Hows your truck running anyway?<br><br>Don~<br><br>
Old Jun 2, 2003 | 10:10 AM
gunracer1's Avatar
it is running hot, i was hoping to use this in a twin set up to cool it down. but it sound like i have a boat anchore, by what i am hearing. so this wont work in a twin set up? mike
Old Jun 2, 2003 | 10:16 AM
Don M's Avatar
DTR Advertiser
I dont know if it will or not. No maps for the turbo and no way of knowing what it will do makes me leary. It might be the greatest thing in the world, but we dont know. Try it out and see what happens Man. it will at least be fun. Grab MK and get to work <br><br>Don~
Old Jun 2, 2003 | 10:35 AM
gunracer1's Avatar
i have already had him look at it and stoped by his shop to compare it to a ht3b he uses for mock up work. i think it would work fine, but i am a bit leary. i am to much of a poor boy to have mark fab me a set up. i will do it all myself, but i will copy his design and layout. hell i am in it 20 bucks, so it is not like i will loose a bunch of money on the deal. mike
Old Jun 2, 2003 | 11:17 AM
shortround's Avatar
A bit more info on the turbo.<br>The entire engine was a military only abortion. It displaced 785 ci and had a nasty habit of pulling the wrist pins out of the # 3 and # 7 pistons. The engine started out as a 210 hp @2100 rpm and the military cranked everything up to 300 hp @ 3000 rpm. The turbo was matched to the engine. There were some other variants of the T50, housing and such, but the T50 was specific to the V555 (also know as a 300 Cummins). We had them for years in our engineer heavy haulers. Grade A POS.<br>The turbo might be nice to play with, HOWEVER I wouldn't want to put it on something of mine. All of our older mechanics cuss EVERYTHING about that engine.
Old Jun 3, 2003 | 04:53 PM
gunracer1's Avatar
the more i look at it , the more i am thinking about useing it. it won't cost me much to fab the manifolds. and if it fed a 700&quot; motor at 3k it should work on my 5.9 at 3500 to 4k. if i feed 30psi into it and get 55 to 60 out i will be happy and cool. should tow like a dream.
Old Jun 3, 2003 | 09:26 PM
1dslram's Avatar
If your going to use this as the big turbo you won't be feeding pressure into the turbo, do you think you can spool this as the small turbo so that the larger turbo can pressure it?<br>Bruce
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
