what should i expect?
Old Sep 26, 2005 | 02:13 PM
mitch@jc'sCTD's Avatar
My truck went into the shopp today and ill be getting it back tomorrow. Im having 375 marine injectors, a trip disc converter, and a valvebaody installed also they are adjusting the timing to 22*. So what should i expect compared to wah t i previously had done?(all that was done is fuel plate foward an afc spring out) thanks mitchell
Old Sep 26, 2005 | 02:18 PM
crobtex's Avatar
Probably a BIG smile!
Old Sep 26, 2005 | 02:27 PM
i sure hope ill have a big smile bc thats all ill have since my wallet is emppty lol
Old Sep 26, 2005 | 04:34 PM
Eskimo's Avatar
Originally Posted by mitch@jc'sCTD
So what should i expect?
With 22* timing, a blown head gasket.
Or, with the injectors, high EGT's.
Old Sep 26, 2005 | 05:21 PM
CTD NUT's Avatar
Expect to be shopping for a new turbo with 370's and a stock plate full forward! Egt's will be nuts.......at the very least, grind the stock plate to a #100 profile and pull it back from full forward but make sure the AFC is full forward! And as Eskimo mentioned, after you have wiped the off your face, expect to replace your head gasket since 22* might be a bit too much advance for your application......cylinder pressures could be too high......the only thing that might save that head gasket is the fact that the stock plate full forward does create a retarded fueling condition and a slight power loss but the #100 will change all that!
Old Sep 27, 2005 | 08:45 PM
My truck isnt out yet bc of tranny line complications but what do you think my timing should be set at so its in a safe place and works to my best benefit
Old Sep 28, 2005 | 08:14 AM
Eskimo's Avatar
Mine is around 16-16.5*, it had slipped to 10-11, and it's much more enjoyable to drive now. If you don't tow at all, i've been told you can go higher.
You'll be REAL happy after you do something with that stock fuel plate, and a 3kGSK!
farmboy56
Mar 21, 2006 02:46 PM
Price_Dog
Nov 27, 2005 10:39 AM
storx
47
Aug 17, 2005 02:27 AM
00turbo
Oct 23, 2004 12:04 PM
maybe2004
14
Oct 26, 2003 01:17 AM
