View Poll Results: What order? (top to bottom)
EGT/Boost
19.12%
Boost/EGT
26.47%
3 gauge setup with other at top
22.06%
3 gauge setup with other at bottom
32.35%
Voters: 68. You may not vote on this poll
What order are your gauges in?
Old Mar 9, 2006 | 09:12 PM
mitch@jc'sCTD's Avatar
top to bottom
tranny temp
pyro
boost
Old Mar 9, 2006 | 09:29 PM
msing's Avatar
top- down to the right oil psi,manifold boost ht3b boost, pyro, fuel psi, drive psi.
Admin edit to fix the IMG link
Old Mar 9, 2006 | 11:50 PM
Moose10's Avatar
Originally Posted by Buckshotmckee
Boost, EGT, Fuel Pressure. The EGT is in the middle because the eyes seem to focus on it easier.
Same setup here.....same reason.....see gallery
Old Mar 9, 2006 | 11:59 PM
displacedtexan's Avatar
Well it looks like my pyro will be goin on the top, which is the same as the middle for those of you with a third gauge. It looked like that would be easier to glane at, and watch out of the corner of my eye...
Old Mar 10, 2006 | 12:00 AM
Timmay2's Avatar
boost
egt
fpr
Old Mar 10, 2006 | 01:15 AM
SmokinDzl's Avatar
Top: Tranny
Mid: Boost
Bottom: EGT
I found it easier to look at the lower/mid pod easier on the eyes while driving than looking up top...therefore tranny (which isn't as critical) went up top.
Old Mar 10, 2006 | 07:51 AM
scottsjeeprolet's Avatar
Pyro, Boost & FP
Old Mar 10, 2006 | 07:58 AM
HOHN's Avatar
I agree. I have boost on top, pyro in middle, then FP on bottom.
I like the EGT in the middle.
I also like having the boost closer to me, as it's a little harder to read with precision.
If I did it all over again, I'd put them in the same order.
jh
Old Mar 10, 2006 | 07:59 AM
hotdram's Avatar
Same here.
~Rob
Old Mar 10, 2006 | 08:12 AM
need12v's Avatar
Pyro
Boost
FP
Love the Isspro's
Thought I had a pic, but not on this 'puter
Soon to come in overhead console:
Air filter restriction, Trans Temp, Rear Diff Temp, maybe a compass or something
Maybe in the little cubby hole in the dash: outside air temp.
Old Mar 10, 2006 | 08:23 AM
RowJ's Avatar
Never realized there was so much thought put into this subject.... or so much variation resulting from all the thought.
All gauges are important.... I just stacked mine in order of urgency, as in data needed "now"!
Pyro...Boost...Tranny Temp
I find the top gauge easiest to see... but maybe being 6' 7" has something to do with that?
Big Jimmy - need to see pictures!
RJ
Old Mar 10, 2006 | 08:36 AM
hotdram's Avatar
Originally Posted by scottsjeeprolet
Pyro, Boost & FP
Wholly crap, is that almost 22 psi of fuel pressure? How are you getting that?
~Rob
Old Mar 10, 2006 | 08:54 AM
big jimmy's Avatar
RJ
I'll try, but it won't be for a little bit- I have twin 5 yr olds and am active w/them etc etc ....
Jimmy
Old Mar 10, 2006 | 09:48 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Mine :
Pyro - Boost - Trans Temp - Fuel Pressure
click on the little picture to enlarge
Old Mar 10, 2006 | 11:04 AM
H2SRDMB's Avatar
gauges?
well from top to bottom. i have egt , trans, boost. then on the steering whel column i have fuel pressure.. i like the egt being top . sits just about eye level
