Vulcan pusher pump install
Old Mar 25, 2006 | 07:16 PM
xmr's Avatar
xmr
I installed the vulcan relocate and big line kit on my truck today. It is awsome. I am getting 14.8 to 15 psi at idle and it will only pull down to 12 psi at wot. Very impressive. My only problem is that I have had to jerry rig my fuel pressure gauge since it would not fit on the top of the filter housing with the new AN connectors from vulcan. I have tried 2 auto parts stores and 2 hardware stores trying to find an adaptor. I guess I will have to order what I need from summit if pep-boys does not have it when I check tomorrow The folks at napa did not even know what an AN -4 fitting was. I just hope the pressuer is not too much for my 15 lb auto meter fuel pressure gauge.
Old Mar 25, 2006 | 10:56 PM
BIGROD's Avatar
Vulcan has a inline fuel tap made to use on the 98.5-99 trucks. I just checked their web sight and it shows the tap made into the 00-02 kits.
Call Eric at Vulcan and let him know what you are needing. He is a good guy to deal with.
Old Mar 29, 2006 | 12:53 AM
ncmech's Avatar
Do you have the contact information for me to talk to Vulcan about fuel systems. I don't know what this Vulcan system you are talking about is. Thanks. Dondi
Old Mar 29, 2006 | 01:53 AM
Ph4tty's Avatar
http://www.vulcanperformance.com/servlet/StoreFront
Or send a PM to Vulcan.
Old Mar 29, 2006 | 07:34 AM
Dr. Evil's Avatar
Lets not forget, Scotty also sells a top quality big line kit:
http://www.scottysystems.ca/smartfuelsystems.html
Old Mar 29, 2006 | 08:20 AM
jiMMyCTD's Avatar
In what way is the kit affecting how your psi gauge affected? Mine is mounted to teh forward most port on top of the housing. i have yet to get a chance to install my vulcan kit....
id say yes your 15lb gauge is the wrong choice.....
Old Mar 29, 2006 | 08:48 AM
xmr's Avatar
xmr
The only reason that the vulcan kit affected my fuel pressure gauge was that I had hard mounted the isolator on top of the fuel filter. When I moved it I had trouble finding a hose. I wound up getting a speed shop to make up a stainless steel hose with 4-AN fittings that the isolator used and getting an adapter for 1/8 npt to 4-AN to put on the port on the filter top. The JIC fittings in the vulcan kit stuck up higher than the banjo fittings.
The vulcan kit is awsome my vp44 seems to run quieter for some reason and the fuel pressure is awsome. Especially coming from a stock lift pump.
I am shopping for a 30 lb gauge to replace my current 15 lb since it stays pegged at idle and runs at 14 to 13.5 at 70 mph. 12.5 at wot.
Old Mar 29, 2006 | 08:53 AM
jiMMyCTD's Avatar
ahhh ok, cuz i simply used a 90* npt elbow to a 2 inch npt stright pipe to the needle valve then line tot eh gauge. I have diprocal 0-30 lb gauge . might work better for you.... id say your pulling at least 17 if not more at idle with the kit...
Old Mar 29, 2006 | 12:48 PM
Ph4tty's Avatar
It is. My 0-15 is pegged at idle, but the guage will still show if my lp is dying or the FF needs to be changed.
Old Mar 31, 2006 | 11:50 PM
ncmech's Avatar
Thank you Phatboy. I talked to Eric at Vulcan today and he will be shipping me the fuel kit tomorrow for my truck. Now I just need to get everything figured out as to what I'll be putting on for FP, EGT, and Boost gauges. I'm thinking the DiPricol gauge kit for pillar mounting from dieselmanor. Just don't know what to do about whether to use an isolator or not.??? Any suggestions? Thanks.
Dondi
Old Mar 31, 2006 | 11:53 PM
ncmech's Avatar
jiMMYCTD, how did you run your fuel pressure line to the DiPricol gauge? Did you use an isolator? What type of line did you use? Thanks. Dondi
Old Apr 1, 2006 | 09:46 AM
bamadzl's Avatar
I've got Vulcan's kit also and the FP gauge is really simple to spice into the fuel line. The vulcan fitting simply fits in-line between the fuel filter and IP.
I highly suggest using a needle valve as others have suggested. Put it right on the vulcan fitting. Close the valve until you crank the truck, then crack the valve as little as you can. This will give nice, steady readings on your gauge.
I chose not to use an isolator due many others experiences of isolator failures. This will let diesel into the cab anyway. I used a 1/4" diesel rated rubber fuel line straight to my gauge. The only downside I found to this hose was the outside diameter of the hose was quiet large. Others will tell you to use stainless hose for peace of mind, which will also work great, but costs quite a bit more.
Brad
4x4dually
35
Oct 19, 2006 12:55 PM
ppsi
Apr 13, 2004 10:18 AM
Mark Thomas
0
Dec 26, 2003 10:32 AM
admin
27
Mar 10, 2003 07:20 PM
Hired Gun
Dec 5, 2002 03:32 PM
