VP44 cost ?
Old Aug 22, 2004 | 09:27 AM
jbeauv's Avatar
VP44 cost ?
What will it cost me to replace my vp 44 if I voided the warranty ?
Here is the problem: 2002 quad cab H.O. 6 speed. Installed Banks 4" exhaust , boost and egt gauges, banks boss hoss 100hp box(yes it taps the vp44 wire), K&N filter,Banks exhaust brake. After spending quite a bit of time on the phone with the banks tech's asking warranty void and being assured that banks equipment would not void the warranty on my truck , I purchased and installed the above components. Afterwards I find out about the Dodge TSB concerning pump tampering (felt a sick feeling in my stomach). The truck has ran fine until now, first symptoms was the momentary loss of power, changed fuel filter, apps reset. tThe truck stumbled again (long trip at highway speeds) replaced the turbo boost sensor and another apps reset. Truck ran worse than before, put old boost sensor back on , checked code (p2016), un hooked the boss hoss module (back to stock) truck seems to be running ok for now, but alot of black smoke, I am 800 miles from home right now traing with the military, but will be returning home in a few weeks. I have an uneasy feeling that the pump will just crap out some where between no where and no where. I know a new lift pump is around $180.00, but does any one know how much a new VP 44 will cost me, Feeling sick in Ft. Rucker AL.
Old Aug 22, 2004 | 12:21 PM
J BODY's Avatar
I've seen remans from 980 to 1400. Then you have to tack on the labor.
Old Aug 22, 2004 | 12:25 PM
59mega's Avatar
jbeauv
you need to check your lift pump pressure asap!!!!
jim
Old Aug 22, 2004 | 02:32 PM
gsdog1's Avatar
P0216 is the death code for the VP-44. I would be having someone follow me home...
I have heard pricing from $900 to $1300 for the VP.
Matt
Old Aug 23, 2004 | 08:21 PM
Jetpilot's Avatar
check here: http://www.piersdiesel.com/DodgeUSPrice.htm
Doug
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
Brad Gray
Apr 15, 2004 07:32 AM
