Van Aaken V5
Old Jan 7, 2005 | 09:57 PM
Dieselcamper's Avatar
Van Aaken V5
I was just about to buy a DDTTPM for my 2001 HO
when I saw the information on the Van Aaken V5
has anyone in here had any experience with this
good or bad ? Lookiking for low end towing power.
Old Jan 8, 2005 | 12:20 PM
Anyone out there try one yet ?
Old Jan 10, 2005 | 09:37 AM
Mark Craig's Avatar
Dieselcamper,
We have sold hundreds over the last year or so and have gotten excellent service and performance from them. The V series is basically going to get you the same max HP as an Edge EZ but customers consistently tell us it gets better low RPM out of the hole torque. Call us if you have any questions etc.
Mark @ DPPI
Old Jan 10, 2005 | 01:23 PM
getblown5.9's Avatar
so they should be making roughly 65hp...and i guess more than 165 tq as thats the numbers for the EZ
this could be an option for me!!!
Old Jan 10, 2005 | 05:12 PM
Thanks for the input Mark. Do you have any info on the
amount of timing advance on the V5. Also with Van Aaken
being around so long why is their V5 less than an Edge EZ or
DDTTPM.
Old Jan 11, 2005 | 08:12 AM
Mark Craig's Avatar
getblown5.9,
They are a little conservative on their numbers, the TQ numbers are a little higher than their claims etc. That's why everybody feels their low end is so strong etc.
Mark @ DPPI
Old Jan 11, 2005 | 08:15 AM
Mark Craig's Avatar
Dieselcamper,
No info on the timing degrees sorry, the reason they are less is anyones guess. I would assume it's because they have been around longer and have amortized (sp) their costs for longer so their cost is lower etc. But don't presume I have the answer on that issue.
Mark @ DPPI
Old Jan 11, 2005 | 09:35 AM
Mark,
I am looking for 350-375 hp, and 700-800 tq, im thinking some stage 2 injectors and the van aaken will put me in that range with managable EGT's as I am pushing 34psi now, but i can feel that its not making any power up top with that boost and no fuel.
Also, does the VA box tap the pump wire?
Old Jan 11, 2005 | 10:31 AM
seabee's Avatar
the van aakens box does not tap the pump wire . you should be some were in the lower part of the 350 to 375 range with that set up . i know with a ez and dd2s and a pdr 35 with a 14 housing you get around 353hp . so i would guess with the van aaken box and a set of dd2s we would get around the same im going threw this to right now . bot im looking to get around the 400 mark
Old Jan 11, 2005 | 10:41 AM
the more power i can get the better...but unfortunately i need a clutch to go any higher, and that wont happen just yet
Battering Ram
110
Mar 25, 2004 06:14 PM
BILL DODGE2003
Mar 8, 2004 12:59 PM
Original Junior
Jan 15, 2004 12:26 AM
GLMaines
Oct 7, 2003 09:31 PM
Copenhagenjunkie
May 19, 2003 08:04 AM
