valve springs or no?
Old Oct 9, 2006 | 11:43 AM
  #76
Marine's Avatar
Veteran: Marine Corp
I would think the cam would lower boost pressure because of the smoother flow caused by longer duration and lift.
Old Oct 9, 2006 | 11:48 AM
  #77
Diesel-Dan's Avatar
My theroy that i would going on was Higher temp = More pressure ; Lower temp = Lower Pressure. Due to the cooler dense air, you would not need as much boost to fill the same amt of volume? Some heat soak skewing boost numbers? Somthing to do with Boyles law, or the Ideal Gas Law....or Charles law.....heck i don't know! That was along time ago when i did this for a grade! haha! HOHN!!!
Old Dec 5, 2006 | 03:20 PM
  #78
Mcmopar's Avatar
Originally Posted by Don M
I have!! the 60 lb springs on the 12V is fine to about 3800, but the truck will rev way out past that. Some float is already occuring though.
I will get with you privately on the fix. It is cheap and simple.
Don~
Did Don ever divulge this fix?? He cannot be reached via PM's and I have no idea what his e-mail or phone number is??
Old Dec 5, 2006 | 03:25 PM
  #79
signature600's Avatar
No, but I haven't asked him either...I'm more worried about the tranny for now, when I get the tranny in and start BOMBing, I'll find out!!
Chris
Old Feb 11, 2007 | 07:08 PM
  #80
HOHN's Avatar
Originally Posted by HOHN
OK fellas, here's some numbers we can put to calculate spring rates.
First, let's calculate effects of boost and backpressure (both of which tend to make it harder for intake and exhaust, respectively, to close the valve. For example purposes, I'm just going to make stuff up.
Let's say you have 50psi of boost max. The applies a force to the valve that tends to keep it open. If the valve is, say, 2 square inches in area, then it is ONE HUNDRED POUNDS of force trying to keep the valve open.
Same thing for exhaust. If you have 50psi of backpressure on that same 2 sq in valve, then you'll have 100# pushing the valve open.
The springs have to overcome these forces.
How to you calculate maximum acceleration of the valve?
First, you need to know the maximum rate of lift of the cam, in inches per degree of rotation (polar coordinates, if you're familiar with that).
Say that the max cam lift RATE is .300" in a space of 60º cam rotation. Assuming it's linear in that section (which is usually the case at peak). So we can calculate the rate as (.300/60º), or .005" per degree cam rotation.
The cam turns at half the speed of the engine, so, then we know the rate relative to ENGINE speed is double this, or .01" per degree of ENGINE rotation
Enter engine RPM. Let's say we're figuring valve pressure for 3000 rpm.
One engine revolution is 360º. At 3000 rpm, that means 360*3000, or 1,080,000 degrees per minute of angular velocity. Call it 18000º per second. At that speed, it will only take 1/600th of a second to move the valve that .300" distance. IN other words 180ft/sec valve velocity.
So now we have to slow this valve down and accelerate it to 180ft/sec in the OPPOSITE DIRECTION, all within a space of about 60º engine rotation.
So the spring has to control an acceleration sufficient to produce 360ft/sec velocity change in only 1/300th of a second. That's an acceleration rate of 108,000 ft/second/second--- or in other words, about 3354Gs!!!!!!
Let's say the valve in question weighs 2 ounces (again, all fictional numbers). Using F=MA, we can see that this 2 oz valve when accelerated by 3354 Gs will act as if it weighed ~420 lbs!
Now, to this 420# figure we add the previously calculated effect of boost pressure or backpressure, which is another 100# of force.
That means that 520# is the MINIMUM spring pressure it would take to control the valve under the circumstances in this hypothetical example.
Still think the Stock springs are up to turning 3K rpm at high boost???
Justin
Sorry fellas-- I was reviewing this and noticed that my cam/engine speed conversion was off. See above quote from proper numbers. Turns out the effective weight of the valve is DOUBLE what I previously calculated!
Wow! This example needs over 500# of spring force at only 3K rpm.
JLH
Old Feb 11, 2007 | 10:36 PM
  #81
Tate's Avatar
JLH
If we are assuming that everything (base circle to total lift) happens within 60º of cam rotation, that would be 120º of crank rotations. So your lift/degree of crank would be .0025in/ºcrank, instead of .0100in/º.
Likewise, angular velocity of crank is 18000ºcrank/sec, cam velocity would be 9000ºcam/sec. Since its the cam we care about, 9000ºcam/sec divided by 60º would be 1/150 sec. Which would equal out to 45 in/sec. .300inx150/sec=45in/sec. Valve closing would be in another 60 degrees. So in total, you'd have .600" travel in 120 degrees cam rotation, you'd still get 45 in/sec. 9000ºcam/sec divided by 120º is 1/75th sec. Being the metric kid that I am, thats what I'll work in.
45in x 25.4mm/in = 1143mm, or 1.143m. So velocity is 1.143m/s
1.143m/s divide by 1/75 sec is 85.725m/s/s.
G=9.81m/s/s. 85.725/9.81 = 8.73G
This gives a pretty low spring pressure, but you'd still have the mass of the lifters, pushtubes, rockers, and bridges to take into account as well.
Now, its been a while since I took physics, but I'm pretty sure all that rambling works out.
Old Feb 15, 2007 | 12:12 AM
  #82
Tate's Avatar
Looking back at this, theres something missing for an accurate acceleration figure. Need to know what the distance from peak velocity in one direction to the peak of the velocity in the opposite direction. If we are assuming .005"/º at a linear rate, the cam would have a nice sharp point, which would give an incredibly small window to go from 45in/sec up to 45in/sec down. If the velocity change took place at 30º from base circle on both sides, giving a 60º window to change a total velocity of 90in/sec, we'd get an accleration of roughly 35g's.
Only real flaw in your math that I can tell is you used 180ft/sec, where it would be 180in/sec. In which case, the acceleration from your numbers come out to 279.5G.
Old Feb 15, 2007 | 01:00 AM
  #83
Ph4tty's Avatar
Only real flaw in your math...
Correcting Hohn on his math?
Don't make him divide by 0!
I'm just messing around, I love it when you break it down for us Hohn
Old Feb 15, 2007 | 01:37 AM
  #84
TheBigNasty's Avatar
Put me on the list for the 12v spring fix!
Old Feb 15, 2007 | 04:53 PM
  #85
Tate's Avatar
I know I shouldn't, but I'm young and reckless.
Old Feb 15, 2007 | 05:28 PM
  #86
dieselfan's Avatar
Can you explain it in layman's terms?
Old Feb 16, 2007 | 07:33 AM
  #87
RowJ's Avatar
How's this! MASSIVE forces are involved in the speed and directional changes of valves opening & closing! Therefore, over 45-50 psi boost... and/or over 3000 rpm.... stronger valve springs are beneficial and highly recommended!
For detailed explanation, in laymans terms, re-read post #32 in this thread. IMO, Don M. covered it all....way back then.
RJ
Old Feb 16, 2007 | 05:11 PM
  #88
dieselfan's Avatar
RJ
No,No, i understand what the springs do or allow. i was talking about the math they were doing (i think).
Old Feb 17, 2007 | 10:45 AM
  #89
RowJ's Avatar
Ah! Misunderstood your question.
Old Jan 8, 2008 | 09:03 PM
  #90
JIT's Avatar
JIT
So what you're saying is most of us NEED to upgrade our Valve Springs!?!?
