Twins setup 3B or S400
I just bought a S400 from Here:http://www.dallasturbo.com/specials1.html
Best price out there.
http://www.turboparts.info/pages/620209/index.htm
Click on the Excel spreedsheet on the right. Part number 167735 has the slip-on (boot) compressor outlet, 4". Part number 167736 has the v-band clamp compressor outlet, 4". Other than that, they are both the same turbo.
I would use some of Rips pieces to do the job, and do some yourself, an S400 flows more than a HT3b and the pipe work is cleaner since it's a clockwise turbo.I'd get his hot pipe and bottom charger bracket then you do the rest. You cant get his hot pipe without the bottom charger support brackt/ oil drain cause his hop pipes are made out of regular exhaust pipe and cant support all the weight of the bottom charger without a support.
Paul
And if you keep looking you can find an even better price.
I called them, and for the same S400 I bought part#171702 S475 from Borg Warner has a 75mm compressor wheel at the inducer 1.32 a/r.
He qouted me a price of $475. $100 cheaper. Oh well.
Thanks for the link.
Yeah but alot of guys run without them, and most likely the do it yourself guys would probably cut that corner if they can, me personally am gonna use a support bracket.
Not bad for $325. Also spotted the p/n 168824 s300 for the same price. It has a huge housing, but that can be fixed. Compressor is a 62 and the turbine is a 71
Buy both and a housing from HTT and you could be ready for twins.
What about a 66/13ss with an S480? Anyone have experiance with this setup? I'd like to use my existing Prostreet in a setup and since lag is not really a concern, I was hoping I could still use it.
You do need to open up the flange, allowing all 6 cyl. to waste.... and you would need a 14 cm turbine on the HX-35.
I've seen this combo turn down the power to about 450 hp and tow heavy, with no EGT problems at all!
RJ
