Turning Up a 12 V
Turning Up a 12 V
What can you do to a 12 for free? Its our shop delivery truck just needs a little more snap nothing major. I have heard of the AFC adjustment or something are there are pics of the adjustments I know nothing about the 12 valves,
Re:Turning Up a 12 V
Slid the fuel plate forward and turn the starwheel. I dont have pics but there are some floatin' around on the web check out www.thedieselstop.com they should have some pics somewhere. Sorry couldnt be more help but all i know is to move plate and starwheel.<br>SD03
if its the company truck I wouldn't recommend sliding the plate without the addition of guages as well as informing all persons driving this vehicle to watch the EGT guage. I wouldn't want to be held personally responsible either.<br><br>Personally Jamie I'd leave it alone since it ain't mine!
I'd try to get along with just some AFC adjustment<br>And I would assure not to be held responsible if something breaks ;D<br>An EGT would be a nice addition. <br>AlpineRAM
Set the timing to correct specs first and then you can slid the plate a little W/O gauges but is best to have them.<br>If truck isn't carrying a big load you could get by with this but if loaded heavy you really need the guages if done. <br><br><br> : Eddie : 8)
Ill agree with bul. Make sure you get the timing set right as well as getting your valves run. If you just turn it up you could increase any effects of valve lash
. I would also go with at least a pyro.<br> Good luck <br> Wheels
Im gonna check the timing but other then that its staying stock by your recommendations! I cannot afford putting a motor in this when some idoit is driving it! If it was me no probs but anyone else no way~!
JoeDiesel
Jan 16, 2011 10:03 AM
boughtadodge
Nov 25, 2002 08:21 PM
