Turbo Sugg. ?
Old Jul 8, 2005 | 09:35 AM
ramtd02's Avatar
Turbo Sugg. ?
Ok here goes.....
I am taking a day off of work too put in my DDT tranny, and pierce my comp wire (FINALLY!! )
Question is will my dinky little hy-35 cool the comp?? I do plan on throwing in some coal sticks in the future (mach 3 or 4), and am wondering which turbo should i be planning on buying? Will an HX40 be sufficient or am i gonna have too hit up the b-1's?
Another question for you guys is i do already have a comp, but i can get my hands on a TST PM3 with remote for dirt cheap. Would it be worth it for me too sell my comp, and get this PM3?? Because I know i can get an EZ and the PM3 for about the same price as i can sell my comp for.
Any suggestions are greatly appreciated.
Old Jul 8, 2005 | 11:52 AM
ramtd02's Avatar
Will a B-1-2 work with this setup?
Old Jul 8, 2005 | 12:47 PM
RowJ's Avatar
It will work...but still get hot. Give you maybe 8-10 sec at WOT before you have to back out of the throttle (hitting 1500*). Anything bigger spools very slowly on an auto. Too slow for me, anyway.
HX-40 won't do it for you, IMO....and the B1-2 on a Comp and Mach 4's will put you over 50 PSI boost, causing possible head gasket problems....as the B-1 line is not wastegated.
Personally, I prefer the TST to the Comp. But I believe the Comp is comparible performance to the EZ stacked on a TST PM3. If I had a Comp that worked well...I would probably stay with it.
RJ
Old Jul 8, 2005 | 01:26 PM
ramtd02's Avatar
i see you have almost the exact set-up i want too run, how does the KSB-1 hold up for egt's?? And what do you have your external WG set at?
as for head gasket problems...whats the best route there?? a marine copper gasket with studs?
Old Jul 8, 2005 | 01:39 PM
RowJ's Avatar
The B-1-2 gives better cooling...I was at 400 HP when I got mine. W.G. set at 45 psi. Over that, all B-1's get hot and gain no HP, IMO.
I can hit 1500* in about 8 sec w/o the water injection.
O-ringed Head and studs is all you need. Maybe just studs...if staying with single turbo and 50 psi boost +/-.
RJ
Old Jul 8, 2005 | 01:45 PM
ridofpwrstroke's Avatar
I got the quick spool from Rip and have the drag comp and mach 4's. It is a stick, but the turbo didnt spool anywhere close to what my hx35 did. Towing anything and I had to back out. I finally bit the bullet and bought some twins. IMO, only way to go with that much fuel. The single was way to laggy. On the dyno with the single I hit 438 hp. With the twins I hit 508 with no difference in fuel. It just burned better. I have head studs and did not fire ring the head. I hit 58 psi of boost. I should be good with this setup. If you are putting this much money in your truck, may as well just do it right.
Old Jul 8, 2005 | 01:46 PM
95ram's Avatar
Have you thought about the HT turbos. Ther're compairable to the b series and have a nice price tag.
Old Jul 8, 2005 | 01:48 PM
ramtd02's Avatar
where can i get an HT turbo?
Old Jul 8, 2005 | 05:12 PM
mooseman's Avatar
htturbo.com, A new vender here. They are awsome people to work with and build very high quality turbos for a decent price. My HTB2 will be here monday .
mooseman
Old Jul 8, 2005 | 05:54 PM
ramtd02's Avatar
Thanks, Looks like if i am gonna get a turbo it will be from HT Turbo.
Hetdiesel
Aug 6, 2009 08:18 PM
Ada381
Feb 10, 2008 07:58 AM
mkeanglorldo56
Jan 5, 2007 11:11 AM
ramtd02
15
Dec 7, 2004 06:20 PM
redram
Dec 10, 2002 09:54 AM
