Turbo comparison
Old Mar 14, 2008 | 02:43 PM
12valvetom's Avatar
Turbo comparison
Is an S300G The same turbo as a super B single? If so what does BD do that makes theirs more expensive than a regular S300G?
Old Mar 14, 2008 | 03:19 PM
GFB's Avatar
GFB
They have the same specs, but a few differences. Talk to Txwelder--he had to do a little modification to get his s300g installed.
Old Mar 14, 2008 | 04:05 PM
kantdrive55's Avatar
DTR Advertiser
It is a similar base turbo. There are some mods that we do to make them different. Ours comes as a kit as well with a downpipe and everything else needed to install.
Old Mar 14, 2008 | 05:35 PM
12valvetom's Avatar
Ok thats what i wanted to know
Old Mar 17, 2008 | 06:15 PM
sledcrusher02's Avatar
turbo
tom, with the bd kit you won't have to find anything else it is very complete!! no running to the parts store looking and hunting for a fitting or a clamp of modifing this or that it's all in the box! and yes it is the same s300g based 57mm turbo. i had one before i outgrew it and held up to more than it should've. if you want pm me and i might be able to find some numbers when i dynoed and info.
Old Mar 18, 2008 | 05:31 AM
Txwelder's Avatar
I did have to modify my wastegate to make it adjustable. There are some tricks to getting it all in there because it is a tight fit. You will have to dent the oil return line where it meets the compressor outlet. Removing the wastegate was necessary for me but it went back on after all else was buttoned up. The turbo fit well once I got the downpipe correct, I made my own. I would suggest for the sake of frustration to get a pre-fab DP. The turbo with my loose and sliping converter made 396/783. Great turbo in my opinion and kept things so cool it was hard to believe. I have the gate set at 35 psi right now but on the dyno it was blocked. Any other Q's let me know.
Old Mar 18, 2008 | 10:35 AM
turbo
i dont know if it was a 12v thing but i didn't have not one issue other than a forgot to get new gaskets.
Old Mar 18, 2008 | 10:41 AM
Lil Dog's Avatar
I had fit up problems with my S300 as the aftermarket (II, HTT, BD, Etc.) all reposition the wastegate to clear the shock towers in the 2nd gen trucks.. Mine contacts the shock tower if the truck is in full torque. I had to shorten up the mounting plate for the gate actuator and just use the boost elbow to control the WG. I will have to order a mounting plate and actuator one day for the aftermarket makers to make it a more official install.
Old Mar 18, 2008 | 04:38 PM
that i didnt have a issue because i run the fabtech dual hoops that do away with the towers.
Old Mar 18, 2008 | 04:45 PM
Big Blue24's Avatar
HMM, sounds like the same amount of hassle I went through to fit a third gen HE351cw to my truck. My turbo flows more air but chokes more on the exhaust side; sixes if you ask me?
schoust
Aug 5, 2007 07:40 AM
getblown5.9
18
May 11, 2006 08:09 AM
metal_miner
Nov 29, 2005 03:25 AM
RowJ
May 3, 2005 12:22 PM
doug
Nov 15, 2002 04:46 PM
