Turbo Break In time?
Old Apr 24, 2008 | 06:42 PM
ramsport59's Avatar
I just installed my II PS62/14 and was wondering if there is a break in time?
It came with Zero info....
Thanks!
Rick
Old Apr 24, 2008 | 06:50 PM
wurkenman's Avatar
Basically no break in. They are lubed with engine oil. If it makes you feel better just run mild for a while, but you should have no issues if there is sufficient lubrication.
Old Apr 24, 2008 | 06:55 PM
Mike Holmen's Avatar
The Guru
Remember to prime the turbo prior to starting the engine. They lossen up after 100 to 200 miles. Try not to get the egt's too hot. After that let the smoke roll
Old Apr 24, 2008 | 07:10 PM
BC847's Avatar
1st Generation Admin
FWIW, my PDR HX35 hybrid came with instructions to go easy the first 50 miles.
Old Apr 25, 2008 | 03:43 PM
Tate's Avatar
My SPS62 came with instructions saying let it idle for 5-10 minutes, then go for a drive and take it easy for the first while. 50 miles sounds good. Then let it rip.
Old Apr 25, 2008 | 04:18 PM
EBunger's Avatar
I have had good luck giving them about 3-4 heat cycles then forget about it.
Old Apr 25, 2008 | 05:02 PM
ramsport59's Avatar
Thanks guys!
Rick
Old Apr 25, 2008 | 07:37 PM
HOHN's Avatar
I say drive it easy until the engine is fully up to temp. Then make a couple 1/3rd throttle runs and let the truck idle for a few minutes. Without shutting down, make a couple 2/3rds throttle runs, then let it idle for a few minutes. Then, without shutting down, make 3-4 full throttle runs to maximum boost.
Since your turbo has likely survived this with no problems, it is trustworthy and will live a long life if not abused.
If it didn't survive, it was going to fail early anyway.
An easy break-in is an enemy to optimal performance of almost any machine. There are exceptions (like diffentials) but most engine-related pieces shouldn't have easy break-ins.
JMO
jh
Old Apr 25, 2008 | 09:00 PM
taken5875's Avatar
first thing I did was get it up to temp then drove it like I stole it!!!! I like to test the limits right away wile things are still under warranty
Old Apr 25, 2008 | 09:04 PM
99globalwarmer's Avatar
just drive like normal, the longer you drive the quicker it will spool, after a while it will be like lightning, hang on your gonna need tires.
Old Apr 28, 2008 | 08:50 PM
The Guru
Hold off on the full throttle shots, until you get some mileage on it. It carbons up the turbo and slow down some of that lighting spool-up later on. The bearing area to shaft is pretty tight. Let it break in, its hard not to want to beat on it. Also when you shut off the truck make sure your pyro isn't above the 350 deg area, this will allow your turbo to last longer.
New2Diesel
Feb 28, 2011 08:28 PM
J Lent
Oct 7, 2009 06:50 PM
Chip
14
Jun 21, 2009 03:59 AM
Red3quarter
Sep 6, 2008 11:56 PM
SjLingenfelter
May 21, 2004 03:18 AM
