Truck started surging bad!!
Old Jan 5, 2007 | 02:26 PM
aggiehorsepower's Avatar
I was driving down the highway today and my truck started surging really bad. It felt as if I was flooring it then lettin off back and forth. I gave it some throttle and nothing happened. The truck didn't even rev up. I was thinking it would be the vp however the truck has no codes, good fuel pressure, and the vp is fairly new. I also thought the tpi or aps sensor or somethin with the throttle. Please if anybody knows anything let me know.
Thanks
Scott
Old Jan 5, 2007 | 05:38 PM
BigBlue's Avatar
Unhook your comp and see if that helps. My old comp would cause the truck to do that sometimes. It might very well be your VP as well. Also, justin had an issue like that and he fixed it by plugging his map sensor back in.
Old Jan 5, 2007 | 06:49 PM
Yeah it could be vp. I turned the comp off and it was still doing it. I had had my map sensor unpluged a while back for only a day but now I have it plugged in.
Old Jan 5, 2007 | 09:10 PM
could it have anything to do with my truck runnin 190-220 degrees like i was telling you tyler?
Old Jan 5, 2007 | 09:43 PM
BigBlue's Avatar
Doubt it. You know how I told you mine was doing the same thing after a hard WOT run? Put that aftermarket water temp gauge on and it doesn't do that. The more I think about it the more I lean towards your injection pump or APPS.
Old Jan 5, 2007 | 10:02 PM
yeah thats true. I hope it aint the vp but we will see. How much is the apps?
Old Jan 5, 2007 | 10:38 PM
ratsun's Avatar
Did you try resetting the APPS?
Old Jan 5, 2007 | 11:39 PM
no not yet. i'll do that tomorrow
Old Jan 6, 2007 | 12:53 AM
dieselrob's Avatar
I had a pretty bad surge with my truck. First it was only wot with the box up on 2 or more. Then it was with the box on or off. Now with the new turbo its smooth as silk no matter what i do. I just thinkit was to much for the hx 35 to have a box and big injectors.
Old Jan 6, 2007 | 11:14 AM
im about to put twins on so i will see what happens after that
Old Jan 6, 2007 | 05:53 PM
dieselrob's Avatar
I might have just been lucky but i dont know. I thought my comp was goin bad cause the surging was gettin bad. But now its gone so time will tell i gues.
Old Jan 7, 2007 | 06:46 AM
Mountaineer's Avatar
I put my bet on apps or maps. I would also try to reset the apps and check the connection of the map sensor and take it out and clean it .
Old Jan 7, 2007 | 10:20 AM
Yeah I will try that and see what happens. How do you reset the apps?
Old Jan 7, 2007 | 11:56 AM
BigBlue's Avatar
Hey scott you in College Station? I've got a better reset procedure than disconnecting the battery and what not.
Old Jan 7, 2007 | 12:04 PM
95ram's Avatar
Try cleaning the map and apps connection. If that doesn't work try recalibrating your apps. I believe BB and I have the same thing in mind. Also try unhooking the edge completely.
