Trailing Arms
Old Sep 15, 2003 | 10:04 AM
SCDAYTONA's Avatar
Trailing Arms
On a 97 4X4, are there any companies making aftermarket replacement trailing arms with poly bushings? Every time I go over a bump, I get a clunk in the front end that I can feel in the floor. The last time I replaced the lower trailing arms with factory replacements, the bushings had slop in them relative to the bolt diameter. Th eprobelm did go away and now it's back again. Truck has 192K on it and has new ball joints as well as axle u-joints about 30K ago. Trackbar was also replaced and is still good.
Old Sep 15, 2003 | 07:03 PM
Hemi Dart's Avatar
Re:Trailing Arms
Rancho makes nice HD replacement links w/ Poly bushings. Also DT makes them w/ Poly bushings.
DT: http://www.dtprofab.com/dodge.htm
A TDR member truck w/ DT's arms:
war machine
Oct 31, 2009 10:06 AM
MAKIN'SMOKE
Sep 17, 2007 07:49 AM
CTD_Neil
19
Oct 27, 2005 09:53 PM
Ryan
Sep 21, 2004 06:49 PM
