Track Bar Questions
Track Bar Questions
My track bar was worn and I recently added a Luke's Link to the ball end to solve the problem. Is seemed to work fine for the first couple of days but then the front end clunk came back and upon checking there was play again. I tighted it up some more and now a couple days later the front end is clunking and there is play? Is this typical of the Luke's Link? Do you need to adjust it a few times before it "seats"?
Am I just waisting my time with the Luke's Link...i.e. should I just shell out the coin and opt for the DT track bar and bracket conversion kit? Does anyone else make a similar kit to DT's that is better or less expensive?
I've already double checked it......The codder pin is in place and the screw in adjuster part has not moved. I just wondered if the bushing inside might have a "run in" period where it will compress slightly? Anyway....I was going to tighten it up a little more and see what happened after that.
Just kind of curious how others on the board made out with their Luke's Link and if I am just wasting my time and should go for the full track bar conversion?
Mine was doing great until I went 4 wheeling and really flexed the suspension. That killed it. After going with the DT track bar is was a night and day difference. The truck drove better than it ever did even when I had the lukes link.
Do a search on track bars...plenty of reading.
DT makes a nice bar, but the heim is prone to accelerated wear. Some guys are getting as little as 5K miles out of them. David is working on an upgrade now.
In spite of what anyone here says, the 03TBK is junk. The bracket may be a fine piece of work, but the 3rd gen track bar has rubber bushings in it, and rubber is the last thing you want in a steering component. I personally know of 4 3rd gen trucks with death wobble from bad track bars.
Your best option by far is this....http://thurenfabrication.com/stocktb.html
I've been running one on my truck for about 25-30K miles now, and it still feels as solid as the day I put it on. It's completely adjustable and rebuildable.
It's also the cheapest of the 3 options.
Most of the Dodge guys on pavementsucks.com are running Don Thuren's bar, and I haven't seen any complaints. Fair number of guys ditching their old set ups in favor of it too.
Thanks.
You can actually tighten the spherical joint on the frame end. Once it wears out, you can rebuild it. Looks to cost roughly the same as a 3/4X3/4 heim.
As far as when....I'll let you know when I get there.
