Torque Converter Lockup Switch...Yes, or is it a NO NO?
Old Apr 27, 2006 | 09:10 PM
Ridiculous's Avatar
i'm thinking about puting one in my truck but it is a daily driver and will this affect anything? can't i just turn off the switch to drive it like normal or what? and also for my original question, do ya'll recommend it or is it too hard on everything?
Old Apr 27, 2006 | 09:42 PM
Mike D's Avatar
If you use the switch for the right reason it won't hurt anything. If you try to do lock to lock shifts, you can hurt your tranny in a way you wished you never heard the words lockup switch...
I've had a lockup switch for a long while now. I use it on the highway only or when I'm pulling a load. You must remember the switch should be used only to keep the converter locked so when you let off the fuel you have some engine braking.
Old Apr 27, 2006 | 09:58 PM
MasseyMan1089's Avatar
I have one and use it allll the time. I know it may be killing the tranny. Sure speeds things up when it shifts locked up. But yes, with it off, the truck is exactly as it was before it was on.
Old Apr 27, 2006 | 10:06 PM
Ridiculous's Avatar
what do you mean exactly by "lock to lock shifts"? and what's the reason it hurts my tranny?
and massey man how long have you been running yours and how many miles with it estimated too?
Old Apr 27, 2006 | 10:11 PM
Lock to lock shifts means you take off from stop with the switch in the locked position. The TC locks up when it shifts to 3rd, then 4th, then OD. Im not sure on the mileage. Mines been on for over 15K
Old Apr 27, 2006 | 10:15 PM
hink's Avatar
if you do it, make sure you get a 3 position switch. 1. locked 2. unlocked 3. factory operaterd. i ran one on my 97 for about 1 1/2 years. i went through 4 TC's. i don't know if thats why, but i believe that it's harder on the TC than it is the tranny itself. i probably used it more than i should have, but i couldn't stand the in and out of the lockup while cruising through town or at lower speeds.
Old Apr 27, 2006 | 10:50 PM
Teddy Bear's Avatar
I say go for it. Just be smart with it. I put one on my truck and it really makes it more fun to drive. Just be smart with it because you can really fry that TC if youre foot is too heavy, mostly below 2000rpm. What its really good for is keeping the TC locked when youre up to speed on the highway. Before i put mine on mine was constantly locking/unlocking. Just dont forget to unlock it when you come to a stop
Old Apr 28, 2006 | 06:59 AM
Mike D's Avatar
Input shaft is what I worry about, but if the TC is stock maybe the TC will slip before the input shaft breaks?
Old Apr 28, 2006 | 07:13 AM
kawi600's Avatar
What about locking the TCC for accelerating hard (and shifting) on something heavier duty like a DTT rig?
I like the idea of a little bit of engine braking
Old Apr 28, 2006 | 07:27 AM
Timberman's Avatar
When you're running the lockup switch in conjunction with an Ebrake, do you have to lock/unlock a lot or what? I ordered a Towlock and a BD Ebrake, not sure how to operate the lock switch on a stock auto tranny. Do you think I'll still have engine braking power down to like 15mph? Kind of confusing.
Old Apr 28, 2006 | 07:54 AM
Mcmopar's Avatar
That is true depending on what mods have been done to the VB, mine will lock in 1st, 2nd, 3rd, and 4th!! I use my lockup switch all the time, GREAT when towing, and fun if you accept the risk to the input shaft.
Old Apr 29, 2006 | 05:24 PM
Yours is a 24 valve though?
Old Apr 29, 2006 | 05:46 PM
Danderson's Avatar
DTT Smart Controller
Consider a DTT Smart Controller. It does the thinking for you! You program the upshifts and downshifts and it dissengages below 30mph,thus saving the TC.
Old May 1, 2006 | 08:47 AM
Mcmopar's Avatar
No, and it doesn't matter which engine you have.
Old May 1, 2006 | 08:49 AM
JD730's Avatar
All that matters is who setup the valve body.
