torque converter lock-up switch
Old Aug 21, 2008 | 05:48 PM
Destination's Avatar
is anyone running a lock-up switch having problems with it seting a code in the computer. the code is for the trorque converter relay. i have checked several times and everything is hooked up like the instructions say on tst's website. the only thing I can think of is I need a better ground source but i dont know. let me know what you think.
thanks for any help
Dick
Old Aug 22, 2008 | 06:33 AM
Redliner's Avatar
If you put a 33 ohm resistor in line with your wire before the switch you do not have to put a jumper in the relay. That is where you are getting your code. Put in the resistor and leave the relay inplace. Works just the same...
Old Aug 22, 2008 | 08:39 PM
thanks man ill give that a try and hopfuly all will be good
THURENfab.
33
Aug 4, 2016 10:30 PM
ProPerDoper
Sep 6, 2014 05:37 PM
rv-ali
Aug 21, 2009 09:22 PM
ataboy9026
Jun 9, 2006 09:08 PM
mr T
May 15, 2004 09:41 PM
