Tightening stock Gov springs????????
Old Dec 29, 2005 | 08:49 PM
Clucker's Avatar
I have read that some guys just tighten stock springs? do you just adjust the low Idle RPM after the adjustment of the springs?
or are you shiming everything but the idle springs?
Old Dec 29, 2005 | 08:56 PM
RCW's Avatar
RCW
It is possible to tighten the OEM stock governor springs from one to three clicks, then have to adjust the idle to get it back where it belongs. However, for the paltry sum of around $30 or so you can pick up TST's governor spring kit with a complete set of instructions, and get even better performance through the entire range. Just tightening the OEM springs can raise the pump defueling profile, but is not recommended for best performance.
Old Dec 29, 2005 | 08:59 PM
Clucker's Avatar
Ive done the 3K install on many trucks but I thought I might try some thing new......
I always got my springs from Piers, so thanks for the TST info I will call them
Old Dec 29, 2005 | 09:58 PM
cumminsdriver635's Avatar
Its about $125 for the 3k governor springs. Go ahead and play around with tightening them. You wont hurt anything anyway. I think you could get some more out of it pretty easily by tightening them.
Eric
Old Dec 29, 2005 | 10:18 PM
Racer9's Avatar
The AFC spring kit is about $30, the GSk is about $120. There is a difference.
Old Dec 29, 2005 | 10:25 PM
TxDiesel007's Avatar
My understanding is simple
You might be able to just free rev or rev the engine higher when doing so, But i do not see how tightening the governer springs is going to affect the fueling curve at all. We replace governer springs to rev the engine higher but it also has the effect of slowing down the governer arm before defueling occurs, why would stock springs slow that down by merely tightening them? Your truck will probably only still fuel to what the stockers allow, it will just free rev higher, IMHO...
If you tighten the springs, u will have to adjust the idle as well...
Tx
Old Dec 30, 2005 | 03:37 PM
12valve's Avatar
we did tighten our stock (215 pump) springs about 1 or 2 clicks, and it would rev up to 4000 rpm on empty, but we didnt find out when pulling! now we have 4k gksk in, we had them there anyway!
try it out Man, you will be happy, specially if you have an older year truck, like a 94, 95 or so, !!
later adjust your ideling with a 10mm.
HorseHauler
Mar 19, 2007 10:14 AM
RC51
May 6, 2006 08:13 AM
fishin fever
Mar 13, 2006 06:46 PM
cumminsdriver635
26
Nov 8, 2005 03:39 PM
BoostdCTD
Jul 5, 2005 12:10 AM
