TC lockup switch
Without a billet shaft, the only lockup shift I'd even consider is 3-4.
I'm not playing until I get a billet shaft, so I don't have the lockup switch.
My trans would shift hard enough at WOT to break the tires loose on the 1-2, if they weren't already spinning..
From: Climax, MI (between battlecreek and kalamazoo)
Originally Posted by SjLingenfelter
Has anyone had any problems running using them?
I hit the switch right at 2nd gear and dang it slams each gear but when i dont flip the switch it doesnt shift as hard.
What's it gain you....2/10ths in a 1/4 mile?
RJ
RJ
There are a few times when I'm towing on steep roads where the truck is only in second gear. I would like the ability to lock it in rather than the trans just slipping. My question is can you just put your shifter in 2nd and hit the switch, or will it only work if the truck is in drive? When you hit the switch is it an instant lock? I don't want to be broke on the side of the road in the middle of nowhere.
Thanks,
Bernie
Thanks,
Bernie
It will not lockup with the gear selector in 2, only Drive. My father and I both use one while towing, it is awsome. I never have to worry about the upshift downshift thing, lock her up and RUN up any hill I find. Just watch the Black cloud following you!
You need to remember to unlock it before you try to stop though
. Yea I forgot
I have let it shift from D to OD locked up, but it hits hard. I use it on the beach in 4LOW-works awsome too. Tranny temps stay nice and low.
. Yea I forgot
Originally Posted by cumminsdriver635
No. I wouldnt worry about it in your case. It only helps with converters that have really loose fluid couplings, and arent putting much power to the ground, like the stock ones do. When i get a good converter, i probably ont use mine near as much, because it wont make my truck any faster then.
Eric
Eric
To fix the input shaft problem I put in a bullet steel input shaft and output shaft. By tranny is the best investment that I made. What good is 600+ hp when you cant put it to the ground. If you guys are having problems with your tranny which you will, you need to get a Hawk Torqueflite tranny. Everything else is crap.
www.htstransmissions.com
So set me straight here. If you have the lockup switch on and you are in "D" on the selector but the trans is in second it locks where, second or "D" Just to keep the confusion straight!!!!
