Sway bar drop brackets
Old Oct 22, 2007 | 10:36 AM
JSPulliam21's Avatar
My lift uses sway bar bracket spacers to keep the front sway bar at the factory geometry. However the rear does not heve these drop brackets or spacers, and is at a fairly steep ange (45*). Is this supposed to be this way, or should Install some drop brackets or spacers?
Old Oct 22, 2007 | 11:53 PM
bob4x4's Avatar
you need to add length to the links to correct the goemetry in the rear addin blocks will make it worse.
Bob
Old Oct 23, 2007 | 09:20 AM
gizzi's Avatar
Don thuren makes longer Links. they are really nice.
Old Oct 23, 2007 | 12:34 PM
I'll check out the Thuren site. What are some reprocussions of this severe angle? Why would spacers make it worse?
Old Oct 23, 2007 | 02:59 PM
bob4x4's Avatar
It would be worse because the bar is under the axle,so blocks under the bar would lower it further.
Bob
Old Oct 23, 2007 | 03:50 PM
I was talking about drop brackets for the top link brackets on the frame. Not the bar itself. I did not see the longer links on the Thuren site. Do you have a link.
Old Oct 23, 2007 | 05:31 PM
bob4x4's Avatar
http://www.thurenfabrication.com
Bob
Old Oct 23, 2007 | 06:05 PM
I meant a link to the links. I went through his site again, and did not see any mention of sway bar end links. Could they be a custom item requiring a phone call?
Old Oct 24, 2007 | 03:07 PM
can17's Avatar
Here, try this.
Old Oct 24, 2007 | 04:44 PM
I know how to get to his home page, and navigate the site. Once again: I went to the site. I looked at every page. I did not see any extended links on any of the pages. If anyone can give me a DIRECT link to the page on Thuren's site where you see the extended sway bar links advertised for sale, please post it.
1985cucv
Nov 11, 2009 09:22 AM
Mike Holmen
Oct 1, 2008 12:50 PM
Cam73
Off Road / 4x4
Jan 2, 2008 12:36 PM
njmaier
Jun 18, 2006 06:50 PM
spunbearing
Apr 3, 2005 11:01 AM
