super B questions
Old Nov 28, 2006 | 10:22 PM
wyomingpower's Avatar
super B questions
all right I have the chance to get a used super b with about 10k on it for 600 to 700. I was wondering what problems these have, if a used turbo is a good idea or not, and what all I would need to put it on (ex. what kind of a down pipe would I need). or should I just save some money for the moment and put on a 14 cm housing?
Old Nov 28, 2006 | 10:37 PM
for got to add the sig.
suddenly occoured to me that I hadnt done anything with my signature yet. hope that is fixed
Old Dec 4, 2006 | 11:52 PM
NMCTD's Avatar
I can't tell you what the turbo is worth used, but you can get one brand new from "turbo supply" for about $800.
They are a good tough turbo, the super B is what BD named the s300g and is what alot of custom turbos are built off of (phatshaft, HTT, and I believe B1)
If you call turbo supply ask for bruce and the part # for the s300g is 174430. You will also need a HX40 down pipe and clamp and atleast 4inch exhaust
Hope this helps....Josh
Old Dec 5, 2006 | 12:24 PM
kantdrive55's Avatar
DTR Advertiser
With our Super B turbo it is a bolt on kit. It comes with the downpipe,clamps and the adjustable wastegate. The wastegate is pre-set for 40psi. We also clock the housings so they bolt right on. Our kit is the only aftermarket kit that has a factory 1 year Borg Warner warranty. We were involved in the development of this particular turbo and wheel setup with BW. We actually are a BW engineering facility. All of these things add value to the turbo.
Old Dec 5, 2006 | 12:34 PM
RowJ's Avatar
Pat,
Aren't earlier Super B's a different set up than what you have now? Have always believed this because the first one I ever saw was bgt used... and it was very slow to spool up... not like mine. I was told it did not have twin exhaust (wastegate) ports. Was on the truck, so I did not see for myself.
RJ
Old Dec 5, 2006 | 12:40 PM
RowJ's Avatar
Originally Posted by wyomingpower
... if a used turbo is a good idea or not, and what all I would need to put it on (ex. what kind of a down pipe would I need). or should I just save some money for the moment and put on a 14 cm housing?
IMO, the Switzer-Borg Warner S300 turbo (Super B) is much newer technology that the Holset. Superior performance and air moving ability! I would sell any Holset I have and change brands!
Super B takes a 4", HX-40 Downpipe.
RJ
RJ
SlingShot
Apr 4, 2011 08:05 PM
Diesel Dave2
16
Dec 20, 2008 07:11 PM
oaborbag
Mar 20, 2008 10:55 AM
roadranger
17
Nov 24, 2007 10:53 PM
Buckshotmckee
Apr 19, 2005 07:20 PM
