sump kit
Old Jul 12, 2012 | 09:17 PM
td3620's Avatar
Post sump kit
Has anybody trying this product.Seeing what yall think of it. (XDP Black Anodized Diesel Fuel Tank Sump Kit )
Old Jul 13, 2012 | 09:37 AM
jhenson's Avatar
If it's what I think I remember seeing, it's just like Joe Hellmans sump kit from a few years back....should work the same.
Old Jul 23, 2012 | 04:44 PM
hhrumph's Avatar
sump kit
Talked to XDP this past weekend about this very item. The idea is that you do not need to drop your tank and attach a aftermarket pump to the VP44.
I'll be getting one and installing the same.
Old Jul 26, 2012 | 03:26 AM
RPM1's Avatar
I have one, install was easy, does what it is supposed to, no more 1/4 tank issues with the draw straw, and doesn't leak. If I remember it was also cheaper then the others out there.
Old Jul 26, 2012 | 09:51 AM
infidel's Avatar
Not that I would ever have one, too much offroading but I only see one port.
What do you do with the return flow?
It really should go back into the tank to aid in cooling the fuel.
Old Jul 27, 2012 | 02:00 AM
RPM1's Avatar
Yes, there is only a single outlet on the sump. I use the stock port on the tank for the return.
MrTwister
Apr 22, 2008 02:23 AM
Chrisreyn
Oct 12, 2007 12:49 PM
Bigredmachine
Aug 4, 2006 12:11 PM
SjLingenfelter
Jan 22, 2005 06:23 PM
