This Sucks!!
Old Dec 29, 2006 | 11:16 PM
efrantz's Avatar
This Sucks!!
Hey I Want To Kill My Self Right Now, My VP Took A **** Today And It Pretty Much Sucks! I Need Some Help And Advice. Were To Buy Cheap/Good and How Hard To Install My Self. I Have Ok Mechanical Skills But I Know My Limit. Thanks Alot Guys And I Hope It Does Not Happen To You.
Old Dec 29, 2006 | 11:28 PM
blackdiesel's Avatar
Registered
the swap is fairly easy. if you know how to turn a wrench and have a few tools, you can knock it out in about 3 hours. you can find a pump for about 1050 or less...
Old Dec 29, 2006 | 11:36 PM
jj3500's Avatar
Wow, that much. OUCH!
Old Dec 29, 2006 | 11:40 PM
efrantz's Avatar
I found one that is 1095 but if you return the old you get 400 back. also is the fass fuel pump good. i mean the one with no filters.
runamuk's Avatar
YEP what you all said is true! Be sure to change your L/P while you are at it for another $200.00!
Full directions are available on DTR!
Rick
Old Dec 29, 2006 | 11:41 PM
Registered
no, they will charge you 1495 then give you your 400 bucks back when they recieve your core....
Old Dec 30, 2006 | 12:50 AM
Tate's Avatar
Rick
$200? Stock carter pumps can be had from Cummins for around $70.
Old Dec 30, 2006 | 01:24 AM
runamuk's Avatar
I guess it all depends on your demographics????
Hot rod V/P's can be had for $1600.00 and I think that your Fass should be well up to the task! What kind of Fuel pressure were you running previous?
Rick
Old Dec 30, 2006 | 08:55 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Almost exactly one year ago, I was posting the same subject.
https://www.dieseltruckresource.com/...injection+pump
My VP died and I had to get the truck towed home.
One HR-VP44 from Doug at Performance Diesel Warehouse, about 5 hours with a wrench and all's well.
My philosophy, if it breaks and leaves me stranded, upgrade it so it doesn't happen again.
Old Dec 30, 2006 | 09:42 AM
crobtex's Avatar
Yes, I have had the FASS with no filter for over a year, and fuel pressure is not a problem. Quality product with pretty simple, straight foreward install.
Old Dec 30, 2006 | 10:16 AM
piperca's Avatar
No up-front core at this place. They give you 30 days ... and the price is right!
Or
You can order it from a local dealer, which you can find using this link, and bring your core down when you pick up the new unit.
Old Dec 30, 2006 | 12:25 PM
efrantz's Avatar
What Pump Should i Get The All HP or the One For My Truck The 235HP
Old Dec 30, 2006 | 12:42 PM
Registered
your truck has a 235 hp pump on it. And thats the one i would get (IMO)
however you could go with the hot rod pump. but you could buy some 300 dollar jammer nozzles that give you 150hp instead of paying 600 bucks for 45~60 hp on the HR pump.... imo
Old Dec 30, 2006 | 12:45 PM
dieselfan's Avatar
i 2nd this, get the 235hp and some jammers, if you want more.
Old Dec 30, 2006 | 03:07 PM
Sidewinder's Avatar
I was checking it out and found the P7100 ELECTRONIC fuel injection pumps as well.
http://www.mwfi.com/p7100.htm
