straight meth
Old Feb 26, 2008 | 10:15 AM
blueboy16's Avatar
straight meth
well i installed a snow stage two water meth kit on my truck lastnight and wehn i got it done i put straight methanol that is run through sprint cars in the tank. and i had the two i think it is 675ml/min injectors in the intake manifold and went for a test drive. well the first time it kick on the motor started making a loud ticking noise and i pulled over poped the hood. OIL EVERYWHERE!!!! blown head gasket. number one cylinder. was it the pure meth or just time for the headgasket to go?
Old Feb 26, 2008 | 10:17 AM
stuckey200224's Avatar
probably both.
Old Feb 26, 2008 | 10:21 AM
blueboy16's Avatar
so if i fire ring and stud the head with a new gasket from ats should i be ok or get rid of the straight meth run 50/50 and get twins?
Old Feb 26, 2008 | 10:26 AM
by fire ring do you mean fire rings or o-rings. if it was mine id run a 50-50 mix not straight ethonol.
Old Feb 26, 2008 | 10:28 AM
blueboy16's Avatar
ats web site says fire ring head includes fire rings and gasket
Old Feb 26, 2008 | 10:30 AM
kawi600's Avatar
It was my understanding that adding methanol increased the cylinder pressures and that straight meth even more so. High timing or more air will also do it.
If youre going to run more power mods in the future its probably worthwhile to get it all done right since the HG popped. Have the block and head checked for flatness and/or decked and then run headstuds and o-rings. You might even look into 14mm studs for more clamping force if you really intend to go high or want a MLS gasket.
That really bites but at least it didnt pop in the middle of nowhere.
Old Feb 26, 2008 | 10:34 AM
blueboy16's Avatar
yea thats a good thing it was like an 1/8 mile down the road. im going to send the head to ats and have then fire ring and get a new gasket and have them send me 14mm headstuds
Old Feb 26, 2008 | 10:59 AM
Ken in AZ's Avatar
Yeah...probably the meth. Recomended max is a 50/50 mix with water for the most benefit without the painful side effects on diesel engines. Using the pure Methanol will actually detonate at our compression ratio which causes simulated advanced timing and thus popping head gaskets - especially stockers - ouch
Old Feb 26, 2008 | 11:07 AM
aksparkey01's Avatar
14mm stud require the block to be drilled and tapped. & i bieleve that fire rings require the block to be machined also. you probally want 12mm studs and an o-ringed head with a marine gasket. and it would be my opinion never to run straight methanol. 50/50 at the most. and that might be too much if your timing is advanced a bunch. Im not sure how the timing is advanced with your computers.
Old Feb 26, 2008 | 11:53 AM
Big Blue24's Avatar
Oring is groove cut in head to allow the addition of a steel oring to put more pinch on the headgasket around each cylinder. 12mm studs is stock size, just get 12mm aftermarket ones and you'll be just fine.
Firerings are cut into the block, steel ring, same principle.
Old Feb 26, 2008 | 11:57 AM
blueboy16's Avatar
ok so a o ringed head 12mm studs and a marine head gasket is what i should do correct?
would that hold about 60 psi with the ii towing twins?
Old Feb 26, 2008 | 12:05 PM
Adam3291's Avatar
Yes, you should be fine then.
Old Feb 26, 2008 | 12:09 PM
blueboy16's Avatar
alright well thats what will be done. just got to get the head off. anyone got any tricks to help it move alittle faster?
Old Feb 26, 2008 | 12:10 PM
AWCampbelll's Avatar
yeah o-rings should work fine. fire-ringing is the fire rings are cut out of the gasket the ring clamps down on the block and o-ringing is the rings clamp down on the fire ring in the gasket. you could have either one done o-rings work better with daily drivers because of the heat cycles.
late,
AC
Old Feb 26, 2008 | 12:18 PM
blueboy16's Avatar
ok thanks for every ones thoughts on the subject. hopefully i can get the head off today and sent tomorrow and then back soon. i called ats and haisley and ats said 3 days then ship back and haisely said at least week and a half cuz they are so busy so i am going to go with ats cuz i need it done.
