Stealth EZ
Old Dec 11, 2002 | 07:57 PM
Johnny RAM's Avatar
Stealth EZ
I got my used Edge EZ yesterday and installed it 'stealth mode'. I put the EZ box under the fuse/relay box instead of on top, it interference fits nicely there. Since I didn't get a boost elbow with my used EZ I put a brass plug, (spent 22 shell), in the waste gate line. I carefully pried open the crimp tensioner part of the factory waste gate clamp with a small flat bladed screw driver then when reinstalling the line just recrimped it with a pair of nippers,(or side cutters), and you can't even tell it was tampered with the green seal paint from dc is still there! Boy do I like the EZ shure helped the bottom end acceleartion. The bombing has begun!
Old Dec 11, 2002 | 08:01 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Stealth EZ
Welcome to [glow=red, 2, 300]"The Dark Side"[/glow] 8)
Old Dec 12, 2002 | 05:36 PM
rattle_rattle's Avatar
Re:Stealth EZ
[quote author=Johnny RAM link=board=7;threadid=8217;start=0#79264 date=1039658262]<br>I got my used Edge EZ yesterday and installed it 'stealth mode'. I put the EZ box under the fuse/relay box instead of on top, it interference fits nicely there. Since I didn't get a boost elbow with my used EZ I put a brass plug, (spent 22 shell), in the waste gate line. I carefully pried open the crimp tensioner part of the factory waste gate clamp with a small flat bladed screw driver then when reinstalling the line just recrimped it with a pair of nippers,(or side cutters), and you can't even tell it was tampered with the green seal paint from dc is still there! Boy do I like the EZ shure helped the bottom end acceleartion. The bombing has begun!<br>[/quote]<br>What boost numbers are you getting with the .22 shell?
Old Dec 12, 2002 | 06:43 PM
patriot pearl blue's Avatar
Re:Stealth EZ
;D i know someone who was able to just pull the hose straight off the factory nipple and not even mess with the clamp ;D<br> hint hint
Old Dec 13, 2002 | 07:08 PM
Johnny RAM's Avatar
Re:Stealth EZ
I'm Getting 26#'s of boost now! ;D <br>Probably doesn't matter much now in the winter with the cool air but will help keep the EGT's down in the summer.
B.A.Ram
Mar 1, 2006 10:35 PM
Moose10
Jul 28, 2004 10:53 PM
TPilaske
Dec 20, 2002 01:09 PM
Cat Cracker
16
Nov 5, 2002 03:51 PM
