Stacking chips
You can stack a smarty programer on the even #'s. (they don't add timming). But your getting about all the good you can out of the vp44 with the juice. You might get more bang for your buck with so bigger sticks. JMO
If you are talented, you can stack pringles or lays on the hood. Doritos are pretty easy to stack but hard not to eat!
All kidding aside, you will see a lot more benefit buying some bigger injectors or nozzles to put on your stock injector bodies. Nozzles vary from 185 to 250 bucks, depending on the size. If you want cleaner power, you will have to spend more money.
acook
Jul 30, 2006 03:17 PM
