Stackin Chips
Old Mar 6, 2008 | 11:41 AM
Redliner's Avatar
Stackin Chips
Can I stack a TST PM3 with a Drag Comp??? Both tap the pump wire. Can I use a Smarty on top of both of them too???
Old Mar 6, 2008 | 06:41 PM
ahire's Avatar
You can run all three but only tap pump wire with TST. And use smarty program w/out timing.
Old Mar 7, 2008 | 06:21 AM
Redliner's Avatar
Will it be worth doing all 3 or just tst - comp stack?
Old Mar 7, 2008 | 09:41 AM
66fordcrewcab's Avatar
Just do the TST Comp stack. No need for the smarty.
Old Mar 7, 2008 | 10:30 AM
Cspotrun's Avatar
The only thing the Smarty will buy you on your 2001 is it will remove the Torque Guard programming for the tranny in the ECM. Other than that it makes about the same power as the COMP/EZ TST stack does. FWIW the Adrenaline is the only fuel/timing box that will override Torque Guard.
PS. I actually was able to send your TST off yesterday. Hopefully its there by Tuesday/Wednesday of next week.
Old Mar 7, 2008 | 03:47 PM
Redliner's Avatar
Thanks alot got trackin number
Bigbc1
Feb 25, 2010 09:51 AM
big_bear_92007
Jul 9, 2008 01:14 AM
genros
Dec 25, 2005 09:46 PM
SjLingenfelter
Sep 9, 2004 02:39 PM
zeik
Mar 17, 2003 07:33 PM
