Source for pitman arm replacement?
I'll be replacing my pitman arm (STOCK - No Lift) and need some help picking out the replacement. That's where you guys come in....
Here's what I've found so far....:
Napa Brand Lifetime warranty for $108
Master Ride Brand 12 month warranty for $42
Any thoughts on which one to get or other sources?
I guess I should ask why you are replacing it? If going to a different size I think you should get what fits but if you are going with a stock replacement I would go with the one that is least expensive. They aren't typically damaged unless they freeze to the sector shaft of the steering box and are damaged on removal. My truck had a drop pitman because of a Skyjunker lift and when i removed it all the splines broke out of it so I ended up getting a stock replacement from the *********** and I think it was around $80. If I was in the market I would get the one for $42. Eric
VaultRam
27
Oct 2, 2014 07:45 PM
Idaho Guy
Dec 13, 2011 11:26 AM
BigDan
Jul 8, 2006 11:04 PM
