Smarty's Now Available in the DTR Performance Shop!
Old Nov 13, 2008 | 10:29 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Originally Posted by robert78.5
I am thinking on buying something for fuel mileage and a little more power at times. Does the smarty have to plug into the obd plug under dash? And if so does it have to stay plugged in while driving?
No it does not unless you want to use the Power on Demand Option.
Old Nov 13, 2008 | 11:56 PM
robert78.5's Avatar
So if you plug it in you can read and clear codes, than set whatever power level you want than unplug it ,it will stay at whatever power level you set it at?
Old Nov 14, 2008 | 08:50 AM
Admin Team Leader
Yes sir....
Old Nov 14, 2008 | 01:55 PM
robert78.5's Avatar
If i have 2 trucks can I use the same Smarty?
Old Nov 14, 2008 | 07:59 PM
rebel5422's Avatar
no smartys are vin number locked it wont let u run programs on two separate truck u have to take it off the first truck to put on the second and i dont think the smarty for an 01 will work on an 05 my 99 has a smarty and an edge juice w/attitude and with both of them on lvl 1 my truck ran 30mpg here in texas and ran 25mpg through missouri the thing in the roof said i was running 38mpg so i had to do the math to bad it wasnt right but i cant complain about 30mpg here even with an auto
Old Dec 2, 2008 | 08:12 PM
blujak01's Avatar
I'm trying to avoid breaking or blowing things up on my truck but i would like to get the smarty tuner and stack it with my banks big hoss chip i have guages an intake and a 4in exhaust is there anything else i should get to avoid ruining my truck or will it be alrite the way it is? any suggestions would be nice im fairly new to the diesel game.
Old Dec 2, 2008 | 08:36 PM
madhat's Avatar
Administrator/Jarhead
blujak, you might want to post this in the 3rd gen section...
https://www.dieseltruckresource.com/...play.php?f=107
Short answer... I don't think that you need to stack them, but you can always try. I do not know much about banks, but if it re-writes the ecm also, you will not be able to use it.
Do you have an aftermarket fuel pump? Tranny mods? If you turn the smarty up, a stock tranny will not last long...
Old Feb 26, 2009 | 10:14 AM
Joe Diesel's Avatar
hey Lary any chance MADS has a canadian warehouse they can ship from so I dont get border taxed to death ?
Old Feb 26, 2009 | 10:21 AM
Admin Team Leader
Joe, I will happily ship one to you via US Postal service so you can avoid those UPS broker fees
Old Mar 3, 2009 | 06:59 AM
Joe Diesel's Avatar
thanks for the offer Lary but ofcourse like clockwork my LP heard i wanted a toy so it dropped in pressure the other day, so my next purchase will be a LP ... thanks again Lary.
Old Jan 5, 2010 | 01:18 PM
bigbad99's Avatar
Originally Posted by rebel5422
my brother bought a smarty a few weeks ago used my comp to update and everything worked fine i have vista so u should be good to go
you can download the software on this link to make it work on Vista http://www.madselectronics.com/DownloadS03A.html
Old May 23, 2010 | 05:24 AM
turbodiesel101's Avatar
do you think my truck would be able to hold the full power of one of these? it has a gorend tc hd valve housings and hd clutch packs. all other tranny bits are stock.
Old Jan 12, 2012 | 03:46 PM
oldkimmer's Avatar
.........OK, ........i have an Edge EZ...would i be better off to take it off and just run the smarty by itself.....i do lots of towing[about 10-12000 max........kim.........
Old Mar 19, 2012 | 05:42 PM
bakdoor's Avatar
I have a few Smarty questions: (1) is this going to work with my in-tank, dealer-replaced lift pump that was installed when my VP44 went down for the dirt nap, (2) will this help give me a little more power for towing my 31' TT? (3) Will this blow anything up and/or harm my engine in any way? I have an '01 with the 5 speed tranny, so I'm not too worried about that part of the equation. (4) Is the Smarty just a plug and play item, or are there permanently installed parts to it? (5) Do I need more lift pump, like an AirDog or something first?
Need advice before pulling the trigger. Thanks!
jthorpe
45
Dec 16, 2008 09:08 PM
Lary Ellis (Top)
95
Sep 15, 2008 11:00 AM
