Smarty Update
Old Oct 1, 2007 | 09:48 AM
hic316's Avatar
Smarty Update
This weekend I was pushing my truck hard with the new Smarty Program that increases the speed limiter, which inturn also raises the rev limiter, and my truck puked.
I hit about 3400 - 3500 rpms and the truck died.
Ended up air managed to get in the fuel lines, thought the vp44 died.
Anyone else have this problem?
I had my smarty on 3, quad box on 3, if it helps.
Old Oct 1, 2007 | 12:10 PM
graphitecumnz's Avatar
I've vapor locked my truck twice... both times it was after lifting off the throttle after making a high rev run....
turns out that my #6 injector line wasn't quite fully tightened down after an injector swap. I am still very careful about lifting off the skinny pedal when it's been mashed thru the floorboard.
Old Oct 1, 2007 | 12:50 PM
Philabuster's Avatar
Do you have stronger valve springs to safely spin your motor that high?
Old Oct 1, 2007 | 06:56 PM
hic316's Avatar
Thats what exactly happened to me, As soon as I lifted off the pedal after a hard run it died.
Nope, looking to do springs soon, right now I am being easy on the truck. What is involved with doing springs, do I have to pull the head, cause if I do, studs and new gaskets are going in.
Old Oct 1, 2007 | 08:51 PM
J Lent's Avatar
You don't have to pull the head to change the springs....just bring each piston to TDC & let the valve drop on to the pistons. I would do some studs if you plan on high revs.
Old Oct 2, 2007 | 07:51 AM
hic316's Avatar
Was thinking about doing head studs, and might as well as if I am already planning on doing springs.
Who makes a good set of valve springs, and how much...
Old Oct 2, 2007 | 12:19 PM
F1 Diesel... $650 is the list price.
duallydave
Aug 27, 2006 02:06 PM
duallydave
Jun 27, 2006 01:21 AM
odie2219
25
Mar 9, 2006 06:18 PM
MnTom
Aug 25, 2004 11:19 PM
