skrewed by overboost code...I think
Old Mar 23, 2005 | 09:48 PM
high country's Avatar
Question skrewed by overboost code...I think
Ok so I put a new cummins map sensor in and....nothin'. I get no smoke most of the time, occasionally I get a good load but 95% of the time it is clear as a bell. My truck gets up and goes very well, butt with fueling enhancements and injectors I feel like it should woof out a cloud. I remember a past thread where BD comented that a past overboost would limit the trucks power. I have put my program in other trucks and they smoked very well but I get nothin' I am looking to get the most for my buck and am about to buy bigger injectors again if that is what it takes. I should note that I saw a very small amount of soot around the turbo/manifold gasket and am replacing that this weekend, I can hit 30-32 psi of boost up a very steep grade while towing and the highest egt I have been able to achieve is 1200 up a 9%
can anyone give me guidence? can I make the code go away? how much if I take it to the *******? oh please set me straight!!!!!!!!
Old Mar 23, 2005 | 11:53 PM
Beast2B's Avatar
if you have a contact at a dealer, get them to look at the codes. any time a trouble code is set, the ECM/PCM takes a 'snapshot' of it. All of the parameters are stored so you can see what happened. I never experienced any residual effects from several overboost codes, the CEL would clear after several good days with no codes, but they always stored in the memory. The dealers DRB can clear codes, some auto parts stores can read/clear codes. Does your Superchips unit read codes? I thought they could read and clear codes...
Old Mar 24, 2005 | 12:52 AM
the superchips does read and clear codes in the ecm but not the pcm and the overboost set a companion code that it will not clear
Old Mar 24, 2005 | 09:14 AM
seabee's Avatar
go down to the local autozone ask them to use there scan tool leave them your id while you run out to the truck and clear the codes . atleast thats what i do when the over boost code sets on mine .
Old Mar 24, 2005 | 10:52 AM
tool's Avatar
hmmmm.......... This I have never heard. I have set several overboost codes on my '99 and erase them with my OBDII Scanner.
O.T
Sep 6, 2007 06:10 PM
volly818
May 16, 2006 09:15 PM
SSV1761982
Jan 29, 2006 03:32 PM
seabee
Feb 28, 2005 02:50 PM
psalm69
Sep 13, 2004 06:34 PM
